MOTM
Popping and Caps
Popping and Caps
1999-10-07 by Mark Pulver
mark scetta (12:28 PM 10/7/1999) wrote:
 >thanks for the backup, TJ! i tried a 0.1uf axial ceramic "104" cap soldered
 >from MOTM-100's OUT ground to tip and am still getting the pitter patter of
 >little feet.... should i try another cap or am i not wired right?
Ceramic 104?
Umm, I'm pretty stale in this but I think "104" can be read as a exponent,
so it would be "10 to the -4" which would make this a .0001uf cap.
I think a .1uf ceramic would be HUGE... Maybe not...
None the less, in order to get the properties that you need to suppress the
spike, you need to use a nonpolar electrolytic...
Mark
Re: Popping and Caps
1999-10-07 by Paul Schreiber
104 is 0.1uf.
101 = 100pf
102 = 1000pf = 0.001uf
103=0.01uf
Paul S.
To: motm@onelist.com <motm@onelist.com>
Date: Thursday, October 07, 1999 12:34 PM
Subject: [motm] Popping and Caps
>From: Mark Pulver <mpulver@...>
soldered
of
>Ceramic 104?
>Mark
