Mod suggestions
1999-02-05 by Dave Bradley
I've been contemplating a couple of mods, and wondered if anyone else has already thought of these, or maybe has actually done them already. How about a gate lamp on the EG? The main problem seems to be that real estate is so tight. Has anyone found a place to put one? Maybe on the VC delayed EG module (when it comes out), there will be room for both a gate lamp and a manual gate pushbutton. On the sample and hold, there is space for an extra jack. I'd like to add an input that allows you to gate track mode on and off. A slightly more versatile use would be for a gate signal to reverse whatever mode the track/hold switch has set. Again, a manual sample pushbutton would be good for when you want to disconnect the clock or to introduce rhythmic variance. Dave Bradley Principal Software Engineer Engineering Animation, Inc. daveb@...
