MOTM
question about the 960 distribution board
2003-03-07 by Chris Walcott
forgive me if I sent this twice ...
I was wondering how this board works.
- Is it an extension of the 900 or is it a replacement board that provides more connections?  I'm guessing the former.
- how does it connect to the 960?  does it come with a bridge cable?
- can you mount it to the side of a case?
The reason why I'm asking is that I'm still considering how I'm going to set up my cabinet.  Right now I'm leaning towards 2 10 space racks sitting side by side.  I'll have the 900 mounted in the rear of one cabinet and I'd like to have the extension board mounted in the second cabinet.  I can drill a hole between the two cabinets to slip the power bridge cable through.
That is, unless I'm missing something ...
- chris
Re: question about the 960 distribution board
2003-03-07 by Mike Marsh
This is exactly how I have it set up, except that it's a single
cabinet. Works great with the distribution board in the center and
the power supply mounted in back and to the right (when facing the
front of the cabinet). I have three of these :) and I need to build a
fourth because I have a single 1U space left.  Which *may*
*eventually* get filled with a new VCA module *someday* when it
*might* come.
I use Paul's rack brackets, 4 to a cabinet.
Mike
second cabinet
To clarify: my cabinets are like two *5* space rackes side-by-side;
each side holds 5 2U modules, so the entire cabinet holds 10 2U
modules.  I have three, so that means I have somewhere around 30
modules (actually more, since I have several 1U modules (actually
actually, I *should* have *at least* one more 1U module, the new
*VCA* except that it hasn't *arrived* yet)).
er, um, yeah.  So I hope that clears it up.
Mike :/
a
> *might* come.
> Mike
space
of
> second cabinet
Re: [motm] question about the 960 distribution board
2003-03-07 by Paul Schreiber
It is not a replacement board. It's like an AC externsion power strip :)
With an *additional* PWR-20 or PWR-30 cable (not included).
Yes. See the NAMM cabinet photos at www.wiseguysynth.com
Paul S.
2003-03-07 by Robert van der Kamp
> > bridge cable?
> included).
Paul, since I ordered the 950 + 960, I guess I also need the
PWR-20 or PWR-30 cable (what's the difference?). I thought
it was included with the 960. Could you add one to my order
please?
(Tried private email but my message got blocked due to spam
issues. Nice...)
Cheers!
Rob
2003-03-07 by ixqy@aol.com
In a message dated 3/7/2003 6:46:18 AM Eastern Standard Time, Robert van der Kamp <robnet@...> writes:
(snip)
 I believe the only difference is in the length of the cable (20" vs. 30").
 Andrew
