MOTM
Why did you pick the cable colors that you did?
2003-03-09 by echophazer
Hello all,
 There was a little talk about the reasons why certain cable color
combinations were picked. I'm wondering what kind of systems other
people came up with in the group.
 I picked one of each cable color in each length. For each set of
similar length cables I used the same color heatshrink. The 2' cable
set has one color heatshrink, 3' another color, and so on... I can
pick out the right cable length from a rat's nest of cables by the
color of the heatshrink. The different cable colors help me trace
them
quickly in a patch. The heatshrink helps me verify that I really did
follow the right cable in a patch.
Unfortunately I had to give up a lot of combinations that I wanted
with this system.
 Recently I had a bad experience where I was in a performance
situation and relied on using cables with 1/4 inch jack on one end
and
1/8" on the other. I was hampered all night because I'd go to pick up
a 1/4" to 1/4" or an 1/8" to 1/8" cable and grab a 1/4" to 1/8." By
the end of the night I decided that I would go back to using only
1/4"
to 1/4" and 1/8" to 1/8" with 1/4" adapters where needed. This
inspired me to adopt a standardized cabling system to avoid
confusion.
Hopefully soon the weather will change so I'll be able to convert all
my 1/8" modules to 1/4".
Ok... enough talk from me...
So why did you do the things
Re: Why did you pick the cable colors that you did?
Yahoo clipped my message.
The last line is:
So why did you do the things you did?
Peter
--- In motm@yahoogroups.com, "echophazer" <echophazer@a...> wrote:
> Hello all,
cable
> them
did
> with this system.
> and
up
> 1/4"
> confusion.
all
Re: [motm] Why did you pick the cable colors that you did?
2003-03-09 by ixqy@aol.com
In a message dated 3/9/2003 6:27:52 AM Eastern Standard Time, "echophazer" <echophazer@...> writes:
> For each set of
 This is what I did too.
 Andrew
2003-03-09 by Adam Schabtach
I already have a bunch of 1' and 2' cables, so I ordered 3' and 4' cables.
All of the 3' are primary colors, all of the 4' cables are secondary colors.
Cables of the same color are differentiated by heat shrink color, although
there are duplicates because I used only white and black heat shrink.
--Adam
2003-03-09 by Mike Marsh
My scheme was real complicated: I picked a color for the cable that
I liked and then picked a heat shrink color to compliment.  The
result?  I ordered ten 4' purple cables with green heat shrink.
Mike
> Hello all,
cable
> them
did
> with this system.
> and
up
By
> 1/4"
> confusion.
all
Re: [motm] Re: Why did you pick the cable colors that you did?
2003-03-09 by J. Larry Hendry
Do, your the one.   <snicker>
Mike
> Hello all,
cable
> them
did
> with this system.
> and
up
By
> 1/4"
> confusion.
all
