Fwd: Milton PCB set
2003-05-03 by jwbarlow@aol.com
I just purchased a PCB set for Peter Grenader's Milton sequencer. I also mentioned that there had been some interest from us MOTM users (especially since we could get Stooge panels made). He asked me to forward this to the list. JB In a message dated 5/3/2003 12:50:39 PM Pacific Daylight Time, petergrenader@... writes:
> I understand this is going to be a problem to MOTM people and I have a > solution. I am not a member of the list. Could I ask you to pass this on > to that list, verbatum, for me?? > > here you go: > > Dear MOTM-ites, > > Greetings. > > I am both flattered and pleased to find that there is a certain amount of > interest in the Milton project among the fine group of synthesists which > embody the MOTM users group. However you are (justifiably) concerned > about > the MOTM pot spacing standards via the relative tight fit of the Milton > pots > (.75 inch centers). > > To this I have a few possible solutions and comments: > > First off, please do not overlook the MOTM Micro Sequencer by Synthesis > Technology as a very viable sequencing solution - it is a marvelous > instrument. > > Secondly, has anyone searched out simular knobs, possibly without collars, > which will match the MOTM scheme? > > Third - the pots currently solder directly to the bank PCBs on the .75 > centers. However, these could be connected however via wires from the > boards to the faceplate mounted pots at whatever spacing you choose. I see > this as a time consuming task, but probably the best, and definitely the > quickest solution . In that the current pot pads sit at .1 inch centers, > three position Molex connectors could be used for each of these, much like > Grant Richter has done with the Wiard pots. > > Forth- If enough interest comes via hard orders, I could investigate the > possibility of having another bank board designed with pot spacing greater > than the current .75. But this would effect the price of those boards due > to the design costs AND the additional material real estate which would be > required to fabricate them. > > You must be very aware of something which will put a hick-up in items 3 and > 4 above: There are 16 pots to each bank. Working the math, using the > standard MOTM pot spacing (1.5 inches) , this would make for a module that > would be well over the length of a 19 inch rack width, which could be > problematic for your application. If the Encore .875 spacing was > incorporated, it would more than likely work out. > > Another solution has been brought to the table by another MOTM user- making > an 4 x 8 step version, as opposed to 16 steps. The current method of daisy > chaining the 4051 decade counter on the Milton engine board could be easily > adapted to forfeit the last 8 steps. This could be done relatively easily. > The bank board however would be a problem due to their width. There is also > the trade-off in functionality which i feel outweighs the benefits. > Therefore, I will not be able to produce such a bank board configuration. > I > would however be happy to supply the electrical, mechanical and timing > conventions so if one chooses, an eight step bank board could be designed > by > a third party > > I hope these solutions offer some possibilities for you. > > best, > > Peter Grenader >
