> I heard that the first module in this series would be the PU-237
> Space Modulator
That was originally correct that Synthesis Technology was going to release
that. But due to some existing agreements, Illudium received the contract and
renamed the unit the PU-37 Exploding Space Modulator (the marketing guys
apparently added the Exploding portion.
This brings to light another long, lost series of MOTM modules, the '000
series. Rarely discussed, but often utilized. The Space Modulator would have
been correctly classified as the MOTM-037 being the first actual module in the
'000 series.
The reverse has also happened where non-modules have been given module
designations such as the '960.
I hope this further clarifies Paul H's point.
Oh, goody!
Shemp
P.S. Some early beta-tester feedback can be found on-line at:
http://www.nonstick.com/sounds/Marvin_The_Martian/ltmm_001.wav
If you listen carefully to the beta-tester, the unit can be heard in the
background at the end of the comments:
http://www.nonstick.com/sounds/Marvin_The_Martian/ltmm_011.wav
Comments after a certain German (and NOT JH) found out about the unit:
http://www.nonstick.com/sounds/Marvin_The_Martian/ltmm_006.wav
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
