MOTM
440 Weirdness
440 Weirdness
2003-06-05 by kirkdegiorgio
OK - hope I can explain this clearly.
I have 2 MOTM 440 LPF's for stereo filter mangling.
I have a stereo synth pad going from Pro Tools to the 440's thus:
Left signal > 440 #1
Right signal > 440 #2
I have a slowish Tri LFO from MOTM 320 feeding CV In 1 of both
440's via a multiple. 440 #1 CV IN 1 knob set to slight negative, 440
#2 CV IN 1 knob set to slight positive. This is for nice subtle
stereo panning.
OK so far. Then I wanted to manually sweep the freq's of both filters
simultaneously... so using 2 banana to 1/4 jack adapters on my Serge,
I patch the Serge Processor into CV IN 2 of both 440's.
Using the -/+5v knob of the Serge Processor I can attenuate both
440's simultaneously right?
Yes - BUT this is working differently on each 440! I can only get it
to work on both filters by setting 440 #1 CV IN 2 knob to fully
clockwise BUT 440 #2 only works the same if I set its CV IN 2 knob
fully counter-clockwise!!
Which filter is behaving correctly??
Kirk
Re: [motm] 440 Weirdness
2003-06-05 by Mark
I'm no electrical engineer, but I'd guess the one that doesn't have
the pot wired backwards.  I'd check the assembly instructions.
2003-06-05 by Kirk Degiorgio
Hi Mark
thx... however this came factory assembled from MOTM... surely not! :-0
kd
2003-06-05 by Richard Brewster
Right.  CV IN 2 on the MOTM-440 is labelled "FM 2".  When fully
counter-clockwise it should be off.  Check the wiring if it isn't.
-Richard
2003-06-05 by Mark
On 6/5/03, Kirk Degiorgio put forth:
>Hi Mark
If they are behaving differently, and all you are using is a simple
mult (and not some sort of multiple attenuator), and your cables
aren't screwy, then they would have to be built differently somehow.
Afaik, they are assembled by hand and nobody is perfect.  I don't
know what documentation comes with the assembled modules, but perhaps
the correct wiring is shown on the schematic.
