MOTM
w
w
2003-06-26 by Norman Fay
>>>4. No imagination. Just listen to the damn radio<<
>When you have a few song writers writing songs for most of todays groups,
>they're all going to sound the same.
A very good point, I think, and not an obvious one, until someone points
it out.  What really annoys me is the routine over-application of
levelling soft- or hardware to EVERY DAMN CD I'VE BOUGHT FOR THE LAST 2
YEARS AT LEAST.  I mean "dynamic" does not necessarily mean everything
at the same level, right?
Norman Fay
RE: [motm] w
2003-06-26 by Les Mizzell
:: What really annoys me is the routine over-application of
:: levelling soft- or hardware to EVERY DAMN CD I'VE BOUGHT
:: FOR THE LAST 2 YEARS AT LEAST.  I mean "dynamic" does not
:: necessarily mean everything at the same level, right?
I do a LOT of music editing for many local and regional dance companies, so
I get to look at the waveform displays on a lot of CDs.  There are many that
still have a pretty good dynamic range - the "Cirque du Soleil" music for
example. Take something like Tori Amos though - sheesh! It's a solid
perfectly smooth thick black line! You're hard pressed to even see bass drum
or snare hits in the display without scanning back and forth through the
waveform to hear where it is....
Jezz....
Re: w
2003-06-26 by gooboworks
companies, so
many that
music for
bass drum
through the
> Jezz....
Maybe this is causing my aural fatigue.   I will put on a CD, and
after a bit, I will just stop it much to my relief.   Now, I am not
talking any kind of grinding, head-splitting, noise puke.   It is any
number of regular CD's.   It is weird, and the best way to describe
it is "my ears get tired".  Does not happen on all CD's, does not
happen with live music, does not happen with TV (lo-fi) music.
There seems to be a level of subtle boringness I cannot clearly
identify.   When I stop the CD it goes away, and I am glad stopped
the music.
This did not happen with old analog vinyl records.   This could also
be natural aging going on, however if that was the case all music
would sound like this.
Well for now, I am going with the smoothing theory.  I guess it is
like removing all the bright colors from a painting, or the sparkly
spices from food.   The end result is bland and dull.
Andy
RE: [motm] Re: w
2003-06-26 by Brousseau, Paul E (Paul)
You've nailed it right on the head-- long durations of highly clipped and compressed music is very taxing.  The worst part is that you can't just turn it down to eliminate the effect; it's still terribly taxing.  My understanding is that this isn't typically the fault or the band, but more often the record label ordering the mastering engineers to make it LOUDER becasuse LOUDER IS BETTER!!!!  <ahem>  This is a fairly recent trend, which is why your records don't hurt, and live shows don't have evil mastering engineers.
(And no, not all mastering engineers are evil.)
I've read that Rush's latest CD (whatsitcalled-- afterburn something or other?) falls prey to this unfortunate trend.  From my own collection, I've noticed that Madonna's "Music" is somewhat taxing.  I can't recall others off the top of my head.
When it comes to this nasty habit, I'd rather listen to grinding, head-splitting, noise puke, ala Merzbow or Aube... at least then I know what I'm getting into.  ;)
--PBr
Sent: Thursday, June 26, 2003 2:43 PM
To: motm@yahoogroups.com
Subject: [motm] Re: w
the music.
Re: [motm] w
2003-06-27 by jhaible
Funny that you mention it - it's only her latest album, isn't it?
Great songs, but overall sound is quite disappointing.
Compressed, and obviously produced to make each song
sound like all the other ones.
JH. (big fan, must have 20+ Tori CDs / EPs)
Re: w
2003-06-27 by coyoteous
Actually, It does come from most of the bands I've worked for. "That sounds
great, but when we put it in the CD changer with X, Y and The Z, it's not as
loud. We want it to be louder than X, Y and The Z. Can you do that?" I use a
number of metering systems including a Dorrough Loudness Monitor and I try
to keep the crest factor (peak to average ratio) at about 12 dB, it usually takes
around 6 dB peak reduction to achieve this with the Waves L1 (or L2) limiter
on top of some mild "riding" compression for moderately dynamic material. At
more than 6 dB of peak reduction I hear the limiter, so I go with multiband
compression to bring the level up from there. Anyway, I also get masters from
all the major mastering houses - some of them have 0 crest factor! But, a good
one can do it with a minimum of harshness. Harshness can also come from
cumulative bit depth truncations...
B a r r y  S t r a m p - evil mastering engineer
--- In motm@yahoogroups.com, "Brousseau, Paul E (Paul)" <noise@A...>
the top of my head.
> --PBr
> From: gooboworks [mailto:andy@g...]
> the music.
Re: [motm] Re: w
2003-06-27 by Gino Wong
More and more these days, Mastering engineers are forced screw up good
originals so that it can be heard o n radio etc...   You can hear just
about every recording pumping before you hear a note.   Weare currently
victims of  golden ear instructions from the top..
Here is the test everybody.  Get out a Major  label CD and it vinyl
brother.    You will listen to the vinyl  twice pops scratches and all
before the CD and will even  physically feel better..
Fashion in technology like Psycho-cosmetology is  just plain wrong.
gw
> companies, so
> many that
> music for
> bass drum
> through the
>> Jezz....
> the music.
> Andy
> Get A Free Psychic Reading! Your Online Answer To Life's Important
> Questions.
> http://us.click.yahoo.com/Lj3uPC/Me7FAA/ySSFAA/VpLolB/TM
> Your use of Yahoo! Groups is subject to
Re: [motm] Re: w
2003-06-27 by elhardt@att.net
Gino Wong writes:
brother.   You will listen to the vinyl  twice pops scratches and all before
the CD and will even  physically feel better..<<
And carrying Computer Music Journal over from another thread, according to CMJ,
listening to CD's has some detrimental effects.  For example, in a test when
listening to CD's people became weaker and couldn't lift as much weight as they
could when listening to analog tape/vinyl recordings.  So CMJ not only was
nearly useless, but also spreading falsehoods like this.
-Elhardt
RE: [motm] Re: w
2003-06-27 by Les Mizzell
:: For example, in a test when listening to CD's
:: people became weaker and couldn't lift as much
:: weight as they  could when listening to analog
:: tape/vinyl recordings.
It's the Slim Whitman "Greatest Hits" CD will do that to you EVERY TIME!!!
Re: w
2003-06-27 by konkuro
Well, I'm certainly in the minority here [heh], but I think if
anything CDs have led to the worst abuse of dynamics.  It is carried
to an extreme, simply because it CAN be. Classical CDs, for example,
are way, way more dynamic than classical LPs for obvious reasons--and
it can be damn annoying!
Unlike frequency, amplitude doesn't carry any information, to speak
of.
Harder to hear
Easier to hear
Harder to hear
Easier to hear
It's rather annoying.
Yea, I'm sounding like a broken record on this subject, but
I'm "warm", a little scratchy, can take a lot of needling, and you'll
want to play me again and again!
johnm
johnm
Re: [motm] Re: w
2003-06-27 by Jay
And this is coming from a Carlos fan? Hmm...
Jay
