MOTM
[motm] easy filter plots
2003-07-13 by elhardt@att.net
Tip for cheap and easy filter plots:
Since I wasn't able to find a software sweep generator and plotter that worked
correctly, anytime I needed to look at the freq response of a phaser, filter or
other device, I had to run white noise through it and then look at an fft
analysis of it.  However, that produces an ugly and crude plot.  So I turned a
synth into a sinewave sweep generator, run that through the device in question,
and record into a wave editor application.  The way it squashes down a wave to
fit on the screen ends up producing just the plots I wanted.  In something like
CoolEdit, one can open up the fft analysis and move the line cursor over the
plot in the background and it will tell you the freq at that point, so you can
tell what frequencies the peaks and notches are at.  Here's a plot of the Nord
phaseshifter:
http://home.att.net/~elhardt/Nord_Phaser_Plot.jpg
Good enough for publishing.  If you don't want a bipolor plot, just chop it off
across the center.  Only drawback is you don't have the log graph overlaid
ontop.  That could be applied in photoshop (or equivilant) though.
-Elhardt
Re: [motm] easy filter plots
2003-07-13 by Adam Schabtach
Yup, an excellent technique. You can also synthesize frequency sweeps in the
computer and use those as the test signal. There is a freeware program
called MakeATestTone which generates AIFF files of frequency sweeps of
whatever duration, range, and amplitude you want. Play the test tone out
through one channel of your audio interface and record the output of the
device through an other channel.
I suppose the first thing one should do when employing this technique is to
loop the test tone output straight back into the recording input, so as to
measure the frequency response of your audio interface.
--Adam
Adam Schabtach writes:
computer and use those as the test signal. There is a freeware program called
MakeATestTone which generates AIFF files of frequency sweeps of whatever
duration, range, and amplitude you want. Play the test tone out through one
channel of your audio interface and record the output of the device through an
other channel.<<
Yes, that sounds just like a freeware program I tried, but there were so many
problems. Just listening by ear I could tell by the changing timbre and hollow
sound of the swept sinewave that it was generating other harmonics. Can't get a
pure sinewave out of this computer. The input back into the computer was so
weak no matter what I tried, the plot was almost non-existant and kind of
sloppy looking anyway. And it only plotted on a linear scale, not log scale.
That's why I dropped that method and turned my Nord Mod into a sweep generator.
measure the frequency response of your audio interface.<<
And I forgot about this one. When doing that, one should get a straight line,
but I was getting all kinds of bumps and ripples so any plot wasn't accurate
anyway.
-Elhardt
