MOTM
.com and MOTM....... uh, ...NO
2003-07-28 by Markk W. Roberts
FWIW, the Synthesizers.com Q130 Clipper module has a FWR section on
it. Should work just fine with MOTM.
johnm
"see below what Paul said, and I quote..."
> > If only they were discussing a partnership.  :-/
"We already did that about 3 years ago. We agreed to disagree."
Re: [motm] .com and MOTM....... uh, ...NO
2003-07-28 by J. Larry Hendry
Yes, but there are several guys out there mixing dot com and MOTM.  In most
every aspect they are quite compatible.  I mixed some too for a short while.
I still mix Blacet, Oakley, Encore, DIY, and even some PAiA into my MOTM
modular.  I have some upcoming Ken Stone circuits too.  Seems as all these
synth designer guys "agree to disagree" on many factors including size,
panels, formats, jacks, etc, all of us users benefit from the diversity of
modular gear available.
Larry H.
Re: .com and MOTM....... uh, ...NO
> From: konkuro <konkuro@...>
> PAIA?  OK, gotta know.
LH:  Spring reverb - good as they get for a crappy spring reverb - 2 tanks.
I need to redo the i/o as I built it pre-modular.  I want to have input
levels normal for line level and modular level, same for outputs, and a
balance control for wet dry.
Vocoder - simply great piece of gear that begs to be hacked and improved on.
I have one more hack planned for mine to add individual band level controls
and a passive HP filter on the front end of the modulating input so I can
ditch using the graphic EQ on the modulating channel.  To those that say a 8
band vocoder cannot produce intelligible speach, I offer the following
samples:
http://www.wiseguysynth.com/larry/vocoder.htm
> I continue to maintain that the future of analog for the next year or two
while will be in "refacing"(TM) modules.  I think the major mfgrs have shot
their wad.
I'm not 100% sure I understand this comment.  But, I think that some of the
best is still to come from MOTM.
Larry H
