MOTM
Multimeter/Soldering Iron Clarification
2003-08-30 by klstay
Since this is all new to me, I don't really know what I need. I have
decided to try building some of the simpler modules. (Paul, you'll
get the kit order next week.) I want a set of building and
calibration tools that will get the job done reliably for years to
come.
I will probably go with a Weller WTCPT. I understand it is reliable
and more than adequate for my level of planned use. However, I still
have no idea what tips to get for building the kits!?!
A good approach for troubleshooting and calibration will probably
only come from experience. Still, I'd like to waste as little time as
possible "thrashing about" at first. Would someone be kind enough to
outline some rudimentary calibration procedures they use for various
modules and the types of tools needed to get the job done.
Re: [motm] Multimeter/Soldering Iron Clarification
2003-08-30 by J. Larry Hendry
> From: klstay <kevinstay@...>
> I will probably go with a Weller WTCPT. I understand it is reliable and
more than adequate for my level of planned use. However, I still have no
Everyone has a different opinion on tips.  I like to use the smallest tips
available.  I personally like the ones that are slighly flattened onthe end
instead of completely pointed.
> Would someone be kind enough to outline some rudimentary calibration
procedures they use for various modules and the types of tools needed to get
the job done.
That has already been done by Paul.  each kit comes with complete
instructions for calibration with note of the tools for each job.  And, if
you do not have a particular tool like a scope, Paul often recomends an
alternate method.
I recommend starting with a meter you are happy with, the nice iron you
mentioned, and your hand tools.  I think that Paul still has a builders FAQ
on his website that recommends hand tools.  I find my vise for holding the
PCB when soldering wires invaluable.  Some people use the expensive panavise
(nice).  I have one that was less expensive and I find completey adaquete.
I also bought a heat gun for the heat shrink tbing.  Seems each kit has
some.  I find I use that for many other tasks around the house too.
If you have these basics, then you can choose to add things like a scope or
a frequency caounter, or whatever as you find you need one.
My $.02
Larry Hendry
2003-08-30 by Richard Brewster
If you plan on building more than a dozen modules, I heartily recommend
both the Panavise with the suction base and PC board holder, and a real
heat gun.  Will set you back over a hundred bucks for both, but you will be
glad you have them.  If you are into DIY, the heat gun becomes essential, I
think.  You can get a supply of heat shrink tubing that will last a
lifetime from Mouser for only a few dollars.
-Richard Brewster
2003-08-31 by Mark
On 8/30/03, J. Larry Hendry put forth:
>  > ----- Original Message -----
Otoh, I use the conical tips with my WTCPT.  It's up to you.  What
you want is the right temperature -- 700 degrees.  The shape doesn't
matter much.
I have a Panavise Rapid PCB Assembler.  It is very nice, but utterly
unnecessary.  You can buy this "helping hands" gizmo at Radio Shack
for $10, take off the alligator clips, and use the bolts to clamp a
PCB right into it.
I probably should buy a heat gun, but so far, I've gotten by without one.
The most important tip I can offer, is do not even think about using
pliers to build the front panels.  I have a set of hollow nut
drivers, as well as several socket sets, but I use combination
wrenches.  Just go easy -- you are building a precision electronic
device, not mounting a diesel engine.  You don't need an entire set.
Off the top of my head, all you need is 1/2" (pots and jacks) and
5/16" (switches and nuts).  You also need a 1/16" allen key (to set
the knobs), a #1 Phillips screwdriver, a little plastic screwdriver
from an alignment set (for the trimpots), needlenose pliers (for
crimping wires), and a small pair of dikes.  Afaik, that's it.
As far as diagonal cutters are concerned, you can get by with a small
pair of electrician style dikes (Klein, Channelock, etc.).  But I
recommend getting a pair that has a much smaller and more angled
head, and short spring-loaded grips for PCB work.  It will be much
quicker and easy to maneuver.  You want a quality pair so that the
blades last (use them only for copper wire of less than the maximum
recommended diameter).  Few hardware stores carry them, but you can
buy a pair online or through a catalog for $20-30.  A small pair of
regular dikes (or even better, a small pair of shears) is good for
cutting cable ties.
You also might want a solder sucker in case you make a mistake.
This is true.  I never used a scope or frequency counter to build
MOTM.  In most cases, the best adjustment is by ear.  The
instructions are extremely good, and if you get stuck, there is an
entire list of people here to help you.
