MOTM
Rails for europe
Rails for europe
2004-07-28 by Luca Pilla
Hello!
I just completed my first rail of motm modules but I have a problem.
Mine screws for europe racks are too large to fit in rails, and the
Motm screws are too small, of course. What can I do? I use racks from
Quick Locks,
thanks
Luca
Re: [motm] Rails for europe
2004-07-29 by Sikorsky
hello there,
i've had difficulty with MOTM rails in M6 based racks (the screw is 6mm in
diameter) - i've found most racks in europe are M6 apart from SKB style
cases and the studiospares stackrack
there are two solutions
1 - if you quiklok rack takes caged nuts, then get hold of some M5 caged
nuts & M5 bolts
2 - get hold of a set of 'humfree' M6 bolts - these have a plastic sleeve
designed to isolate the rack unit from the rack - strip the plastic sleeving
off and the bare section will fit onto the MOTM rails...
cheers
paul b / sheffield
