MOTM
MOTM-820/OMS-820
MOTM-820/OMS-820
2004-08-18 by charlesosthelder
Hi all!
I've just added the now-discontinued Oakley OMS-820 companion module
to my MOTM-820 lag processor.  If you've got the MOTM-820, you will
LOVE the extra functions the OMS-820 adds- VCLFO and VCEG.  Tell Tony
to reintroduce this module and sell you one!
It may be necessary for me to buy another MOTM-820 and build the OMS-
820 for it just to have TWO!
Chub
Re: [motm] MOTM-820/OMS-820
2004-08-18 by Scott Juskiw
I agree. I have two MOTM-820/OMS-820 combos and they get used in
every patch. I was surprised when Tony said the OMS-820 wasn't
selling well.
BTW, it's also good for manually generating a gate signal (for those
self running patches that need a boot to the head to start up).
2004-08-18 by Richard Brewster
I built two MOTM/OMS-820 modules also.  Mine are in 2U wide Schaeffer
panels I designed.  I simply omitted the bypass function on the MOTM and
the pushbuttons on the OMS to compact everything into 2U.  I also added
another comparator to detect "near zero" output, that generates an
end-of-cycle pulse.  Patching this to the GATE input gives a new
oscillation mode:  0 to +5V, which resembles in function the famed Serge
Dual Universal Slope Generator.
Got a question for you MOTM/OMS 820 owners.  Have you ever noticed an
irregularity in the period of the oscillation?  I see this in both LFO
modes (the OMS original, plus the mode I added).   When the period is on
the order of a few seconds per cycle, there will occasionally be a short
cycle, a period slightly shorter.  It seems to happen randomly, every 5
to 10 cycles.  I don't know for sure if this happens across the entire
frequency range, but it's most noticable as described.  I have read
through the theory of operation on the MOTM-820 and studied the
schematic.  I don't completely understand the relationship between the
control voltages and the slew rate.  The OMS-820 puts the MOTM-820 to
wonderful, unintended uses!  I like it very much, even including the
period anomaly, which has musically interesting applications -- another
"source of uncertainty."  I have plenty of dependable MOTM LFOs when I
want a rock-solid period.
-Richard Brewster
P.S. -- Scott, your "self running" patches need to be kick started?!  :-)
>selling well.
2004-08-19 by Scott Juskiw
I often have "events" that get triggered from random sources.
Sometimes, those random sources aren't happening often enough when
I'm tweaking a patch. I like to be able to generate a gate "on
demand" rather than waiting for the random source to generate one for
me.
But I also find microwave ovens too slow at heating my lunch; two
minutes is a long time in dog years.
Re: MOTM-820/OMS-820
2004-08-19 by tontaub
> me.
Also, when chaining ENVs in a feedback loop (simply spoken), one of
them has to start going - then you'll need a kick start as well.
   ;-) Michael.
