MOTM
duophony
duophony
2004-08-25 by David Moylan
I know it's archaic by some standards, but I've had the guts of an old
Paia CV keyboard controller laying around for a while and have finally
put a circuit together (EFM KBD2E board) to put it to use.  It's working
good and I've been hacking a second board to add douphonic capability.
I have the choice know of setting the second voice to double the first
if only one note is pressed or to remain silent.  So, if one note is
pressed it, either one VCO in a typical patch or both VCOs play note 1
until a second note is pressed, when the second vco would switch to the
second note.
Any opinions on either configuration?
Thanks.
Dave Moylan
Re: [motm] duophony
2004-08-25 by Scott Juskiw
Both configurations are useful. If I could only choose one, I'd
choose the former (double the first if only one note is pressed)
because it will retain a more constant volume with both voices
playing in unison, and single note runs will be fatter with both
voices playing in unison.
Re: [motm] duophony
2004-08-25 by J. Larry Hendry
I agree.  If I could make it switchable, I would because sometimes you might
want the two voices to be something completely different.  Maybe a bass line
and a lead line for example.
Larry H
Yahoo! Groups Links
