Re: VC EG .. add Ribbon Controller.
2004-09-01 by J. Larry Hendry
---- Original Message -----
From: John Loffink <jloffink@...> Due to the unofficial stooge/motm non-proliferation of EGs pact I doubt this will ever be stooged. --LH-- I've never heard it put that way. "Non-proliferation pact", sounds like a weapons system agreement. :-) But, seriously folks, we do sometimes take a position not to make certain panels simply because we believe it will pull cash flow out of MOTM land. Our goal is to suppliment the experience, not to cut into into the founder's business. :-) I think all you guys that have been around for a while understand that, but maybe the newer guys need to hear it anyhow. The Schaeffer / Front panel Express option is always there for those that feel that need. I think that is great. But, Dave and I do not have to go against our particular beliefs when those panels are made. As I see it, the MOTM-800 EG is the cash cow that helps support everything else that happens in MOTM land. So, that is where Dave and I stand. One day that may be different when / if circumstances change in MOTM land. Speaking of panels, I have ordered the PAiA ribbon controller. I am not certain exactly what the ribbon element will be like. I am expecting something leaning toward the cheap which is the norm for PAiA (not a bad thing at times). However, I am very excited about the circuit. It has many features of a ribbon control module that I have been discussing with Dave Bradley for some time (a high and low note from the same resistive element). And, I can see from the schematics that this should work quite well with the Doepfer Ribbon element. I think the Doepfer Ribbon element is awesome. However, the Doepfer module is a total piece of crap IMO. So, if the PAiA circuit is all that it is supposed to be, I can see an opportunity for Doepfer Ribbon (thow away the module), PAiA ribbon kit (luckily they sell the PCB and electronics parts separately from the wood and control panel), and Stooge panel with MOTM like implementation. I have mine on order. Web site says shipping in September. In PAiA-speak, that probably means early next year. Who knows. But, I plan to build one up and start playing with the idea of a Stooge panel. :-) Stooge Larry
