FW: [motm] Rear Mounted Power Supply
2004-09-28 by Tkacs, Ken
Scott, you should really consider insulating that switch handle... <g>
-----Original Message----- From: J. Larry Hendry [mailto:jlarryh@...] Scott's system is so big he needs a special switch to turn all of those power supplies on at the same time. It's a rather big knifeblade (about 70 lbs worth). http://www.midiwall.com/wall/switch/sw_002.jpg <snicker> Stooge Larry ----- Original Message ----- From: Scott Juskiw <scott@tellun.com> At 2:24 AM +0000 2004/09/28, black_man_music wrote: >I serached the archives and didn't quite find an answer to my >question, which is... > >If I mount my power supply in the back and I cannot access the >switch, is it OK to turn off/ >on the system using my Furman AR-1215 voltage regulator? Thanks!! > Yes. I have several cabinets with rear mounted power supplies all plugged into one power bar. I use the switch on the power bar to turn the whole thing on and off.
