that neural agonizer
2004-11-09 by Sikorsky
hello all, first off many thanks to scott for this brilliant unit - i unexpectedly finished it over the weekend (it's amazing what a new soldering iron does for my wiring stamina) so i had a bad day at work yesterday and foolishly decided to wind down by calibrating the neural agonizer - oops anyway, i eventually just powered up my trusty TR808 and spent a happy hour playing the same loop through the reverb, using the mix out to feed the drive input so a tip and a question if you use the accutronics tanks, mine at least came with alternative spring assembly mounting holes - so instead of having to drill another hole in the tank for the second input, i was able to neatly enlarge an existing hole with a countersink. a couple of turns was all that was required to fit a barrel type phono plug (the kind that bolt directly to the panel as opposed to being fitted to a plastic flange which attaches to the panel) also, i never found a european 1/8 socket for the tank cabling, so i just wired it direct - an MTA156 is annoyingly close, though 0.1" barrier strip of some kind might do it now the question - i decided to go for a pair of type 9 tanks with medium decay, does anyone here have an alternate set of short decay tanks..? (i'm wondering about getting an alternate pair) cheers paul sheffield / uk
