MOTM
Pitch Shifter
Pitch Shifter
2004-12-27 by THE_BEAT_MAKER
Hi, Does anyone know of a company that makes an Analog Voltage
Controlled Pitch shifter? (MOTM Quality)
Re: [motm] Pitch Shifter
2004-12-27 by Sikorsky
All together now: ENCORE ELECTRONICS FREQUENCY SHIFTER
www.encoreelectronics.com
and it's 'stereo' too
cheers
paul
Re: Pitch Shifter
2004-12-27 by mate_stubb
Strictly speaking, a pitch shifter is different than a frequency
shifter. Pitch shifting maintains the harmonic relationships,
frequency shifting mangles them as it spreads them.
Frequency shifting is hard to do precisely, but I've personally never
heard of a VC pitch shifter. Maybe some of the Lexicon or other rack
effects boxes which do pitch shifting have a VC input, but they are
digital anyway.
Which exactly were you interested in?
Moe
RE: [motm] Pitch Shifter
2004-12-27 by Adam Schabtach
Um, no. A frequency shifter and a pitch shifter are not the same thing.
--Adam
(primary author of Discord, Audio Damage's pitch shifter plug-in, and of a
not-yet-released frequency shifter)
Adam Schabtach
adam@...
www.audiodamage.com
Re: Pitch Shifter
2004-12-27 by paulhaneberg
There is no such thing as an analog Pitch Shifter.  At least as far
as I know.  I suppose one could be built if you could find a charge
coupled bucket brigade type device capable of high enough quality,
but that's unlikely.  All pitch shifters are digital and break the
incoming signal into samples just like digital delays.  There are
always trade offs involved in making a pitch shifter as well, as
improved pitch accuracy and improved timing accuracy are somewhat
mutually exclusive.
I think what you are really looking for is a pitch shifter which can
accept a control voltage to control the amount that the signal is
shifted in pitch.  This is also difficult to accomplish.  Most
Digital Delay devices which are capable of analog voltage control
actually step between delay values rather than continuously changing
value.  This tends to cause zipper noise.  In order to vary the
delay (or the pitch) continuously the sample rate clock must be
voltage controlled.  While not impossible, this is quite difficult.
If you are sampling at 48 kHz which would give you a maximum input
frequency of around 20 kHz, and then you wanted to either decrease
the delay time or raise the pitch by two octaves, your sample rate
clock would now be running at 192 kHz.  If you slow down below 48
kHz you will lose high end response or generate some truly nasty
artifacts, so the effective range is only about 2 octaves using
modern converters if you want to be continuously variable without
stepping.
It may be possible to get more range with a delta/sigma scheme or by
using a flash converter with a compander.  This is something I'm
personally interested in exploring, as I'm interested in the musical
applications of delay lines, but I haven't had time to play around
with any kind of circuit design yet.
The frequency shifter is another animal entirely.  The Encore
Electronics module is quite wonderful, but as someone else pointed
out a frequency shifter does not maintain the integer spacing of
harmonics present in the input signal, so it really does not shift
pitch.
Re: [motm] Re: Pitch Shifter
oops
i think i got over excited on that last post and didn't read it properly, so
repeat after me:
Eventide H949 Harmonizer
you can get them in the uk for around \ufffd250, the pitch can either be voltage
controlled or clocked via a VCO
i've got an H949 and i love it - i'm not too sure what facilities are
available on the H910 which is far cheaper on the s/h market
as far as i know, the H910 & H949 are analogue pitch shifters
cheers
paul (ducking this time)
To: <motm@yahoogroups.com>
Sent: Monday, December 27, 2004 6:47 PM
Subject: [motm] Re: Pitch Shifter
> mutually exclusive.
> stepping.
> pitch.
Re: Pitch Shifter
2004-12-27 by Tkacs, Ken
Way back in the 70's I used to get a pitch shift effect by driving an analog delay with a sawtooth control voltage. It's quite crude, and the saw needs to be pretty pure (not too hard with an MOTM oscillator driving it), and it has to be "positive-going" (back then we called 'inverted' sawtooths 'ramps' but that distinction seems to have faded with time and the terms are used interchangeably now). You could hear imperfections in it, but I thought it was kinda cool at the time.
KAT
RE: [motm] Re: Pitch Shifter
2004-12-27 by John Loffink
According to the Eventide web site the H910, their first harmonizer, is a
"versatile digital delay line" and harmonizer.  So the pitch shifting is
digital, not analog.
John Loffink
The Microtonal Synthesis Web Site
http://www.microtonal-synthesis.com
The Wavemakers Synthesizer Web Site
http://www.wavemakers-synth.com
> From: Sikorsky [mailto:vulture.squadron@...]
> Sent: Monday, December 27, 2004 1:23 PM
> To: motm@yahoogroups.com; paulhaneberg
> Subject: Re: [motm] Re: Pitch Shifter
> oops
> so
> repeat after me:
> you can get them in the uk for around £250, the pitch can either be
> voltage
> cheers
Re: Pitch Shifter
2004-12-27 by cormallen
> as I know.
If I remember correctly, the mathematician Dennis Gabor (of Gabor Wavelet fame) built an
analogue pitch-shifter using a drum wrapped in tape and read/record tape heads that
rotated around it.  All completely analogue, but I suspect it didn't exactly sound like a
high-end Eventide :-)
Harry
hello all,
i had to go look at the manual - the Eventide H949 is indeed digital
so that would be a case of too much wine and not enough harmonizing
still, it is xmas...
cheers - paul
2005-01-03 by Mike Estee
AFAIK there are *no* analog pitch shifters. It's a very expensive
effect and one that doesn't lend itself to analog circuits too well.
Feel free to prove me wrong though :) As far as a CV controlled pitch
shifter, your best bet is probably the Eventide Eclipse. Its voltages
are a little different, and you can't just plug something straight in
(need funky cable), but it does work. As a word of caution, I've found
that the company has a rather "snotty" attitude and can be a bit
difficult to work with, but they make great effects. (Well, except
there delays, but anyway...)
 From the manual:
"Stereo 1/4-inch connectors. The sleeve is ground reference, the ring
is a +5 volt (source),
and the tip is an analog signal between 0 to 5 volts input to the
Eclipse. Connect either foot
switches, foot pedals, or control voltage sources to these inputs to
modulate parameters or
to trigger events"
If you want a frequency shifter I highly recommend the Encore
Electronics MFS01, it's awesome :)
--mikes
> is a
> is
> John Loffink
> > oops
> properly,
> > so
> > repeat after me:
> > voltage
> > cheers
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <122603_LREC_bkup_BR_Ashanti.jpg>
> <l.gif>
> 	•	To visit your group on the web, go to:
> http://groups.yahoo.com/group/motm/
> 	•	To unsubscribe from this group, send an email to:
> motm-unsubscribe@yahoogroups.com
> 	•	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
