MOTM style knobs for d-shaft
2005-01-09 by Jim Carlile
Does anyone know if MOTM style knobs are available for d-shaft type pots?
2005-01-09 by Scott Juskiw
At 12:38 AM +0000 2005/01/09, Jim Carlile wrote: >Does anyone know if MOTM style knobs are available for d-shaft type >pots? I've put MOTM style knobs onto D-type pot shafts. I didn't get any kind of special knob for D-shafts, I used the standard knob. The set screw just goes onto the flat part of the shaft. More significant is whether or not the pot is attached to a PCB or is mounted to the front panel. Best if it's mounted to the front panel, otherwise you can have a knob whose minimum position is 4 o'clock and whose maximum position is 2 o'clock.
Thanks for the tip. I'll see if the standard MOTM knob fits on an Octave CAT and lines up properly.. that would be nice. These particular knobs are the same style wise, but don't have a set screw. Instead they have a little metal insert inside them that keeps it to a d-shaft. Some of these pieces are corroded and the knobs don't really stay on well, not too mention they are all scratched up.. thats why I'm looking for replacements. -Jim --- In motm@yahoogroups.com, Scott Juskiw <scott@t...> wrote: > At 12:38 AM +0000 2005/01/09, Jim Carlile wrote: > >Does anyone know if MOTM style knobs are available for d-shaft type > >pots? > > I've put MOTM style knobs onto D-type pot shafts. I didn't get any > kind of special knob for D-shafts, I used the standard knob. The set > screw just goes onto the flat part of the shaft. More significant is > whether or not the pot is attached to a PCB or is mounted to the > front panel. Best if it's mounted to the front panel, otherwise you > can have a knob whose minimum position is 4 o'clock and whose maximum > position is 2 o'clock.
2005-01-10 by icmman2001
Actually, I retrofitted my Octave Cat with standard MOTM knobs because of the same problem (not to mention a few missing...) They work perfectly. Digi-Key also sells the colored slider caps that are identical to the old ones Octave used... even in the same colors. That, and some new Pratt-Read keyboard grommets, and the synth will be practically (cosmetically, at least) like new. -Tim --- In motm@yahoogroups.com, "Jim Carlile" <eibbs@h...> wrote: > > Thanks for the tip. I'll see if the standard MOTM knob fits on an > Octave CAT and lines up properly.. that would be nice. These > particular knobs are the same style wise, but don't have a set > screw. Instead they have a little metal insert inside them that > keeps it to a d-shaft. Some of these pieces are corroded and the > knobs don't really stay on well, not too mention they are all > scratched up.. thats why I'm looking for replacements. > -Jim > > --- In motm@yahoogroups.com, Scott Juskiw <scott@t...> wrote: > > At 12:38 AM +0000 2005/01/09, Jim Carlile wrote: > > >Does anyone know if MOTM style knobs are available for d-shaft type > > >pots? > > > > I've put MOTM style knobs onto D-type pot shafts. I didn't get any > > kind of special knob for D-shafts, I used the standard knob. The > set > > screw just goes onto the flat part of the shaft. More significant > is > > whether or not the pot is attached to a PCB or is mounted to the > > front panel. Best if it's mounted to the front panel, otherwise you
> > can have a knob whose minimum position is 4 o'clock and whose > maximum > > position is 2 o'clock.
