On Feb 7, 2005, at 9:04 AM, J. Larry Hendry wrote:
> > I'm (finally!) just about to mount my first flat rails. Since the
> mounting
> wholes on the front panels are bigger than the screw's diameter
> there's some
> play when mouting.
> Yes, this is part of Paul's design slop to allow for fit. The same
> is true
> on the 19" rack rails.
> > When mounting several flat rails in a row, what's the nominal gap
> between
> the rails?
> When butting the rails end to end, there is zero gap. They are a
> full 6U
> wide.
> > And is the upper/lower edge of the rails flush with the top/bottom
> edge of
> the panels?
> That depends on the cabinet. In theory, the rails should be flush or
> up to
> 0.0075 higher (top) or lower (bottom) than the panels. I have found
> the top
> row of my slant cabinets you cannot put them all the way out against
> the
> wood. The truth you will find is that the measurements in your wood
> cabinets cannot be near as accurate as those in metal. Therefore,
> you can
> adjust the flat rails somewhat as needed to compensate.
> > My intention is to use one 2U and two 1U panels as templates, ie.
> assembling panels and rails before mounting the rails.
> This is the perfect plan. You can leave the screws loose so when you
> get
> your flat rails where you want them, the panel should still "rattle
> around"
> on the loose screws so that you know the fit is good for all panels.
> The best way is to use two 1U panels in positions 2 and 5. If you
> look at
> the flat rail wood screw holes, you will see you can still get to all
> 4 of
> them with 1U panels in positions 2 and 5. That was no accident. :-)
> Here are some photos of me installing flat rails in a dot com
> cabinet. Some
> of the issues with spacing and positioning are discussed.
> http://www.wiseguysynth.com/larry/cabinet/dotcom/dotcom.htm
> Larry
> • To visit your group on the web, go to:
> http://groups.yahoo.com/group/motm/
> • To unsubscribe from this group, send an email to:
> motm-unsubscribe@yahoogroups.com
> • Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
