MOTM-650 'manual'
2005-02-26 by Paul Schreiber
The 'core' of the MOTM-650 is the Europa upgrade for the Jupiter 6. Info here: http://www.synthcom.com/Europa/europaFaq.html The MOTM-650 is designed to be the most feature-rich MIDI-CV ever made. It has 14 user-defined tuning tables, true 16-bit DAC/voltage reference/output path, dedicated 8-channel, 10-bit DAC for the AUX functions, and both constant rate and constant time portamento. Did I mention a full MIDI Clock "engine" than than both multiply AND divide by a *fraction* of MIDI clock? BTW: there is an expansion port on the rear to daisy-chain up to 4 of these at once :) Paul S.
