MOTM '120
2005-04-25 by rafael_cohen@prusec.com
Hi Paul & all, Just curious about the '120 via holes. When I got to the instructions to solder the "via holes" on the '410 I realized I had not done it on the '120. Was I supposed to? Did I miss that instruction somehow? Thanks, Rafael
2005-04-25 by Scott Juskiw
>Just curious about the '120 via holes. When I got to the instructions to >solder the "via holes" on the '410 I realized I had not done it on the >'120. Was I supposed to? Did I miss that instruction somehow? The via holes should always be filled in, but it's not always mentioned in the instructions. You can always fill them in at a later time, just make sure you use the no-clean solder.
Thanks! I haven't tested them yet, but I'm glad I got this figured out
before I tried to troubleshoot.
Scott Juskiw <scott@...>
To: rafael_cohen@...,
motm@yahoogroups.com
Monday April 25, 2005 01:51 PM cc: Subject: Re: [motm] MOTM '120
time, just make sure you use the no-clean solder.2005-04-26 by Scott Juskiw
I'm taking a head count on a new panel that I want to have made in the upcoming Stooge panel run. The panel requires some custom work beyond the normal painting and silk screening (punching out square holes). Stooge Industries has graciously offered to do this custom work, but they would like to know how many of these they are likely to sell so they don't get stuck with a bunch of extra metal. Also, I would like to know how many PCBs to order when the time comes. Here's the main page for this new project: http://www.tellun.com/motm/diy/tln854/TLN-854.html If you are interested in panels, PCBs, or both, please email me and let me know. I will coordinate with Stooge Industries. Thanks
