MOTM
First "magic bus" cut
1999-11-14 by J. Larry Hendry
Well, I finally got around to turning talk into action tonight and cut and
drilled out the first one of "Larry's magic bus" as the thing got dubbed
some time ago.  Essentially, this is a horizontal multiple panel that is
designed for the big ole' wood case approach.  The bus is 7/8" tall and 42"
wide (that's 24 MOTM units).  I duplicated Paul's spacing (as close as I
could tell) for Switchcraft jacks on the MOTM panels.  So, each jack is
spaced on 7/8" centers with the end jacks centered 7/16" from the end.
When this multiple and normalling patch bay is installed directly under one
row of MOTM modules it will look almost like one more row of jacks on the
bottom of each panel.  Now, I just need to get busy and make some more and
look for a paint shop.
I do like the way it turned out since the space allocated for each jack is
7/8" both wide and tall.
Larry (and his crazy magic bus) Hendry
