Update/MOTM-650/MOTM-995
2005-09-16 by Paul Schreiber
a) the new connector board MOTM-995 is at wave solder (along with 25 MOTM-960s!). This *replaces* the 'stand-alone' MOTM-900PCB board (it is still integral to the MOTM-900). The '995 has 4-pin, 6-pin and 3 of the .com MTA-100 connectors. The function is to convert MOTM<>.com without fancy harnesses. In order to power .com modules (cough), you *must* use a MOTM-950 (NOT a '900). Many .com modules use +5V. I will add this to the existing order form on Sunday. I will be able to ship beginning Sept. 26th. b) I am starting the pc board layout of the CPU/DAC board for the '650 today. This is a 4-layer SMT board. There is a change in how 2 MOTM-650s can daisy-chain to form an 8-voice system. Originally I was going to use Ethernet patch cords. But I don't have the room. So I am using 14-conductor ribbon cable. In order to use 2 MOTM-650s in 'sync', all you do is connect the 2 together. I will have cables available. There was a scheme in place (but not yet coded) to allow up to 4 to be connected (16-voices!) but the limit is now 2 (8-voices). Of course, you can have *multiple sets* of 2 MOTM-650s. If you haven't placed an order for one, now is a good. time. I won't charge your credit card until it's ready to ship. This allows me to plan ahead in terms of the # of units going out the first 2 weeks. c) For newbies: just to let you know the schedule for the upcoming months. Last day to "cash in" module points: Nov. 15th (see the PDF catalog) Last day to place kit orders for 2005 delivery: Dec. 1 Last MOTM work day: Dec. 15th Return from holiday: Jan. 15th MOTM modules make the ideal holiday gift :) Just don't wait until Dec. 10th to order! Paul S.
