MS-20 info received
2005-10-11 by Paul Schreiber
Thanks to all that responded. I am getting the data to include in the V/Hz table for the '650. In case you were wondering, low 'C' is 1V (approx.) so the other Cs are like 2V, 4V, 8V above and 1/8, 1/4, 1/2V below. So what I did is calculate the "middle C" MIDI note (#60) octave voltages, then just simply half/double the values each octave. Someone is verifying MS-10/MS-50 does the same thing (which I'm sure they do). Paul S.
