Can a MOTM900 power this?
2005-10-14 by brownchonald
Can a MOTM-900 power supply, somehow, power this VCO: http://www.musicfromouterspace.com/analogsynth/VCO200503REV01/VCO200503REV01.html ??? If not, how should I go about powering this module? Sorry if this is the wrong place to post this question. Not sure where else. Cole
2005-10-14 by Ben Vehorn
The MOTM 900 is +/- 15V, so yes, it should work. According the website, it can be made to run on 12V or 15V.
On Oct 14, 2005, at 5:01 AM, brownchonald wrote: > Can a MOTM-900 power supply, somehow, power this VCO: > http://www.musicfromouterspace.com/analogsynth/VCO200503REV01/ > VCO200503REV01.html > ??? > > If not, how should I go about powering this module? > > Sorry if this is the wrong place to post this question. Not sure > where else. > > Cole > > > > > > SPONSORED LINKS > Label > Cd music label > Independent music label > > YAHOO! GROUPS LINKS > > ▪ Visit your group "motm" on the web. > > ▪ To unsubscribe from this group, send an email to: > motm-unsubscribe@yahoogroups.com > > ▪ Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > >
(cc:ing the list so someone can correct me if I'm wrong) The MOTM 900 has a distribution board to connect modules and it uses MTA-156 4-pin connectors to do so. You would need to buy one of these MTA connectors and wire it to the ends of the power wires coming from the VCO board. 2 of the MOTM's connections (the ones in the middle) are for ground so one of these would be left empty. The website for that VCO says it can run off 12 or 15 +/-V but I have no idea if you would need to build or calibrate it differently to run on 15V, as it looks like the default is 12V.
On Oct 14, 2005, at 6:07 PM, brownchonald wrote: > Awesome. How would I connect the MOTM900 power supply to this VCO? > > It looks like the PCB only has three holes for +12V, GND, and -12V (or > 15, using the motm900). > > How would I wired the 900 power supply to these three holes? > > Thanks, > Cole > > --- In motm@yahoogroups.com, Ben Vehorn <mathlete23@c...> wrote: >> >> The MOTM 900 is +/- 15V, so yes, it should work. >> According the website, it can be made to run on 12V or 15V. >> >> On Oct 14, 2005, at 5:01 AM, brownchonald wrote: >> >>> Can a MOTM-900 power supply, somehow, power this VCO: >>> http://www.musicfromouterspace.com/analogsynth/VCO200503REV01/ >>> VCO200503REV01.html >>> ??? >>> >>> If not, how should I go about powering this module? >>> >>> Sorry if this is the wrong place to post this question. Not sure >>> where else. >>> >>> Cole >>> >>> >>> >>> >>> >>> SPONSORED LINKS >>> Label >>> Cd music label >>> Independent music label >>> >>> YAHOO! GROUPS LINKS >>> >>> ▪  Visit your group "motm" on the web. >>>  >>> ▪  To unsubscribe from this group, send an email to: >>>  motm-unsubscribe@yahoogroups.com >>>  >>> ▪  Your use of Yahoo! Groups is subject to the Yahoo! Terms of >>> Service. >>> >>> >> > > > >
