Re: Cap Placement & Solder & Iron Tips
1999-11-23 by Elhardt@xxx.xxx
hugo.haesaert@... writes: >>That no-clean solder "wet's" a bit harder, i think it has to do with the flux used, but i've experienced no "tooth-paste" effects.<< I experimented trying the different solders on a junk circuit board using scrap components. I found the no-clean solder flowed nice and freely also. So I figured I would just go ahead and use it instead of the organic. But after I washed the board and saw how clean the section looked where I used organic, I went with the organic. I hate trying to plan how much soldering I can do within a two hour timeframe, but I am getting away with only two board washes per board, sometimes washing serveral boards at once. When I order another batch, I should have it down to one wash per board. Now I need to work on getting solder iron tips to last more than one day of use. Geez. I retire my Ungar with its crappy copper tips and buy a new iron that uses nickel plated tips. They look like stainless steel so they give me a false impression of long lasting straigth. No luck. I still go from nice fine point, to dull, disintergrating, hollow volcano tip within hours. -Elhardt
