AR EGs?
2005-11-08 by Mike Marsh
Hi All - I'm in need of several AR-type EGs. Does anyone know of small boards/kits for such beasts? Tony used to sell some as I recall, but, well... Thanks, Mike
2005-11-08 by Scott Juskiw
An AR EG is one of the simplest circuits to make. All it takes is two diodes, two pots, one cap, and an op-amp voltage follower. Maybe a couple more resistors to trim the output down depending on how large your gate signal is. You can easily build this on one of my MUUB boards.
>I'm in need of several AR-type EGs. Does anyone know of small >boards/kits for such beasts? Tony used to sell some as I recall, but, >well... >
Cool! Assuming (and this would be a good assumption) that I am completely lame when it comes to electronics, is there somewhere where a circuit like this is diagrammed? How many EGs on one of your big MUUBs? 4? Thanks, Scott... Mike --- In motm@yahoogroups.com, Scott Juskiw <scott@t...> wrote:
> > An AR EG is one of the simplest circuits to make. All it takes is two > diodes, two pots, one cap, and an op-amp voltage follower. Maybe a > couple more resistors to trim the output down depending on how large > your gate signal is. You can easily build this on one of my MUUB > boards. > > >I'm in need of several AR-type EGs. Does anyone know of small > >boards/kits for such beasts? Tony used to sell some as I recall, but, > >well... > > >
2005-11-09 by Scott Juskiw
Using the simplest possible AR (one op-amp per EG), you can fit 4 of them on a MUUB-4. If you want a fancier circuit, then you'll get 2, or 1 EG per MUUB-4. I'm not publishing any MUUB circuits until after the contest is over (Dec. 1). This might be a good contest entry (hint hint).
>Cool! Assuming (and this would be a good assumption) that I am >completely lame when it comes to electronics, is there somewhere where >a circuit like this is diagrammed? How many EGs on one of your big >MUUBs? 4? >
2005-11-10 by Richard Brewster
Well, it isn't quite that simple. You want the output levels to be independent of the gate level, so that requires internal gate processing. You also want a good curve on the release, so it reaches cutoff at zero after a reasonable time. A nice example for an AR EG is found in Electronotes #92, p. 13. Ian Fritz published a design that derived from an earlier idea by Carl Hovey in EN#31. I would use different gate processing than Ian's, which is TTL based. I am thinking of breadboarding this on a MUUB-4 and entering the contest. It will be interesting to compare three different AR EGs on the MUUB-4, with 1, 2, or 4 EG circuits. -Richard Brewster Scott Juskiw wrote:
>Using the simplest possible AR (one op-amp per EG), you can fit 4 of >them on a MUUB-4. If you want a fancier circuit, then you'll get 2, >or 1 EG per MUUB-4. I'm not publishing any MUUB circuits until after >the contest is over (Dec. 1). This might be a good contest entry >(hint hint). > > > >>Cool! Assuming (and this would be a good assumption) that I am >>completely lame when it comes to electronics, is there somewhere where >>a circuit like this is diagrammed? How many EGs on one of your big >>MUUBs? 4? >> >> >> > > > > >Yahoo! Groups Links > > > > > > > > > >
