MOTM
VCO FM question
VCO FM question
2005-12-07 by gregorykjar
Hi
I´m still a bit new to MOTM and dont have any MOTM VCO´s yet. (using
my old Korg Mono/Poly as main VCO´s) Can you do FM in the "Yamaha DX7
way", with it? (feeding/modulating it with its own or another VCO´s
output) Or is this only possible in a virtual digital domaine?
greetings
Gregory
RE: [motm] VCO FM question
2005-12-07 by Paul Haneberg
In order to do DX type FM you need the ability to linearly frequency
modulate a VCO through zero.  While the MOTM-300 is capable of linear
FM, it does not have through zero capability.
I'm unsure whether or not you need oscillators which reset to zero on
the leading edge of a gate.  This may not be necessary, but I assume the
DX series does reset to zero.
Even if the MOTM oscillator was capable of meeting the above criteria,
you would need a very large system to replicate the DX7.  Six VCOs, Six
VCAs, Six Envelope Generators at the minimum.
Personally, I would welcome a new MOTM VCO with these capabilities, but
I haven't heard anyone else except Dave Bradley express the same
sentiments.
Paul H.
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
gregorykjar
Sent: Wednesday, December 07, 2005 1:50 PM
To: motm@yahoogroups.com
Subject: [motm] VCO FM question
Hi
greetings
Gregory
Yahoo! Groups Links
2005-12-07 by Scott Juskiw
You can make FM sounds with MOTM modules, you
just can't get the precision that you get with a
digital synth (like DX7) in terms of keeping the
modulator to carrier ratios precise all the time.
You can create gongs sounds quite easily, but if
you manage to tweak the controls to make a good
FM piano sound at one frequency, it will not
sound so good with other notes for very long; the
slightest drift in oscillator frequency (or
phase) will make it sound like hell. This is
normal for analogue synths and it wasn't until
the DX series that useable FM became a reality,
and for that they had to go digital.
Re: [motm] VCO FM question
2005-12-07 by john mahoney
You can do the "feeding/modulating it with its own or another VCO\ufffds output"
thing. Like X-MOD on the Mono/Poly.**
As Paul H. wrote, however, it's a long way from there to doing it the
"Yamaha DX7 way".
It's been widely stated that VCOs are not accurate enough for true, DX-style
FM work, and that is why Yamaha went with DCOs. But maybe it was also a
matter of cost? (Well, we *know* that cost is always a factor.) Question is,
how accurate do the oscillators really have to be?
john
** I have a Mo/Po, too. Turned it on the other day for the first time in
months, and it was not tracking in tune. It's been perfect for over 20
years, so I was a little bummed. Hopefully it's just a matter of
calibration, but I'm fearing that caps and/or some CMOS chips are due for
replacement. Not rocket science but it will be hours of work. :-/
To: <motm@yahoogroups.com>
Hi
I\ufffdm still a bit new to MOTM and dont have any MOTM VCO\ufffds yet. (using
my old Korg Mono/Poly as main VCO\ufffds) Can you do FM in the "Yamaha DX7
way", with it? (feeding/modulating it with its own or another VCO\ufffds
greetings
Gregory
Re: VCO FM question
Hi
Well, I didn´t want to make a complete DX7 replica. You can get a
long way with just 2 VCO´s, with an EG and a VCA to control the
feedback/FM. I´ve tried that in Reaktor, but then again thats in the
virtual world. It would be great with real knobs.
Do you by "through zero" mean that it goes down to zero hertz and
then through to "negative" (phase reversed?) frequencies? (within
one cycle)
I realise this is probably not an easy design task. Just wishing :-)
greetings
Gregory
frequency
linear
on
assume the
criteria,
VCOs, Six
capabilities, but
> sentiments.
> Paul H.
Of
> gregorykjar
> Hi
(using
DX7
VCO´s
> greetings
> Gregory
Re: VCO FM question
Last year my old Mono/Poly hadn´t been turned on for some years
and was completely dead. I tracked the problem to a pcb connector that
just needed a little massage. Luckily because removing the PCB is some
work.
It´s a well constructed synth and I used to think that an EG was an EG
until I turned on the MOTM-800 the first time. On the paper "just
another EG" but my compliments to Paul. The 800 is a really good EG.
On the Korg (and a lot of other synths) you have fast, middle and slow
(more or less) but the 800 really gives you all the inbetweens.
Well, I´m getting CV and gate from the Korg and I´m about to build in
some buffers so I get Modwheels and LFO´s out of it too. Hope it´ll
work some more years, its a nigthmare to track down malfunctioning
electrolytics and other stuff.
greetings
Gregory
time in
20
due for
RE: [motm] Re: VCO FM question
You are correct in your understanding of what through zero means.
It is my understanding that through zero modulation can be achieved with
a triangle core VCO, but not with a sawtooth core VCO.  But the VCO must
be designed with this in mind and the design is not trivial.
Paul H.
gregorykjar
Sent: Wednesday, December 07, 2005 2:46 PM
Subject: [motm] Re: VCO FM question
Hi
one cycle)
greetings
Gregory
frequency
linear
on
assume the
criteria,
VCOs, Six
capabilities, but
> sentiments.
> Paul H.
Of
> gregorykjar
> Hi
(using
DX7
VCO´s
> greetings
> Gregory
Yahoo! Groups Links
2005-12-07 by Neil Bradley
Not to mention that FM synthesis in the Yamaha line of synthesizers is
really not FM synthesis - it's phase modulation synthesis.
http://en.wikipedia.org/wiki/Frequency_modulation_synthesis
-->Neil
Neil Bradley            "If you owe the bank $100, it's your problem. If you
Synthcom Systems, Inc.   owe them $100mil, it's the bank's problem." - JP Getty
Yes, through-zero FM means a phase reversal when
you go through 0 Hz. This is another critical
feature to get that DX sound. I've tried to
replicate DX patches on my MOTM synth and
although I can create good FM sounds, I can't get
them to sound exactly the same as a DX.
>one cycle)
Re: [motm] Re: VCO FM question
2005-12-08 by Ben Vehorn
Talk about timing, this was just announced on the AH list:
http://www.cyndustries.com/
>  >one cycle)
> YAHOO! GROUPS LINKS
> 	▪ 	 Visit your group "motm" on the web.
> 	▪ 	 To unsubscribe from this group, send an email to:
>  motm-unsubscribe@yahoogroups.com
> 	▪ 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
