For current '650 owners.....
2006-04-14 by Paul Schreiber
Several folks have emailed me about having the '650 act erratically when: a) the unit is receiving MIDI and at the *same time* b) you change a parameter using the front panel buttons Now, certainly, if you are changing Voice Modes (Allocation or Grouping) this is to be expected. Also, changing MIDI channels on-the-fly is confusing, because note on/off info has "lost sync". However, if you see strange stuff just scrolling through menus while MIDI is received (like running from a sequencer program), then let me know for sure. There should not be hangs or funny stuff when changing things like AUX assignments or Portamento, or thinngs that do not effect note off/on data. Remember, I need to reproduce the error here. So, *be very specific* when reporting errors. If I can replicate it, and the programmers can't replicate it, how can we fix it? Paul S.
