MOTM
820 Question
820 Question
2006-04-28 by xamboldt
I'm currently building my 820 kit, and I've been planning a few mods
(basically the oakley 820 mods done on a perfboard since the PCBs are
no longer available).
One thing I'm wondering about before I solder in the ICs - the bypass
jack seems designed for a foot switch, but it also looks like it'll
work with an external signal - if the signal is low, the lag is
enabled, if the signal is high, the lag is bypassed. Does it work
like that? There's 10K1 ohms of resistance between +V and the jack -
if I did hook up another module's output to the bypass jack, could it
hurt the other module?
Basically I hacked together a method to use one of the unused CMOS
switches and a comparator to enable the bypass jack to work with no
problem with either a foot switch or an external voltage. Before I
solder the CMOS switch in though, I want to know if I should bend the
pins my mod would need out, or if I shouldn't bother since, for the
reasons stated in the paragraph above, this mod might be unnecessary.
Thanks for any help you can give!
-Chris
Re: [motm] 820 Question
2006-04-28 by Paul Schreiber
Yes, you can use a voltage to bypass it as well as a footswitch.
Paul S.
2006-04-28 by Scott Juskiw
You don't need to change anything, it will work fine with an external
voltage plugged into the BYPASS jack. It was designed that way, says
so in the docs.
2006-04-29 by xamboldt
Thanks, guys. I got it completed and it does work with voltages,
although it actually doesn't specify that in the docs as far as I
could tell. The only time it ever mentions using a voltage with
regards to the bypass jack is to say that there's a diode in the
circuit to protect it in case one connects a negative voltage. The
overly cautious among us might read that as an implication that
you're not actually supposed to hook voltages up to it. Anyway - it
works!
One small possible non-issue - when I hook the bypass jack up to a CV
source that is only positive-going (800 EG, for example), the lag is
bypassed when the voltage goes below a certain threshold, but the
Bypass LED does not light up. The only time the Bypass LED lights up
is when the voltage goes negative (or if I touch the tip of the patch
cord to ground). The functionality is fine in this case, but the LED
doesn't necessarily show the status of the bypass - is this normal?
-Chris
> so in the docs.
2006-05-01 by Mark
On 4/29/06, xamboldt put forth:
>could tell.
I don't think does either...
Yes, when controlling it with a jack, the LED does not necessarily
show the status of the bypass function -- the effect can be bypassed
and the LED can be off at the same time.  Notice the base of Q1 and
the control input to the MUX are on opposite sides of a resistor.
While it doesn't require a negative voltage to function properly, the
bypass input needs to "see" a low enough impedance in order to turn
off Q1.  When connected to an MOTM-800 it sees 2K.  Although, I don't
know why the bypass LED doesn't use one of the two unused switches on
the MUX.
2006-05-01 by xamboldt
Hi Mark,
Thanks for confirming this for me. I had the same idea about the
unused CMOS switches. I put that IC in a socket so I might mod mine
to use one of those to control the bypass LED more accurately.
For those keeping score at home, my rough plan was to disconnect Q1
from the bypass circuitry (by removing R6); use the unused NC switch,
leave one end attached to Ground, and hook the other end to the base
of Q1 (in the Q1-side hole left by R6), also put a 10K resistor
between +V and the base of Q1, then connect the NC switch's control
pin to the other control pins of the CMOS switch. Then. This should
probably do the trick.
Maybe just lowering the value of R6 would work as well, instead of
all the rewiring I just mentioned? What is R6's purpose?
I can't say that I'll get around to trying this any time soon. I
still have a few more modules to build, and for me it's more fun to
get new ones working than to tweak ones that already work fine.
-Chris
>> could tell.
> the MUX.
