MOTM
Four MOTM-700 VC Router patches
2006-07-04 by John Loffink
Full wave rectifier
Ingredients:
Signal source
MOTM-700 Dual VC Router (1 stage)
Oakley OMS-802 Mixer/Triple Attenuator (need gain of -1)
Signal source to MOTM-700 CV IN and IO B
Signal source to OMS-802 IN1
OMS-802 OUT1 to MOTM-700 IO A
OMS-802 IN 1 knob at -5
MOTM-700 switch knob at 0
MOTM-700 mode switch to voltage
MOTM-700 output is full wave rectified waveform
Pulse Divide by Two
This divides a square wave frequency by two. Good for clocking/gate
applications or suboctave square waveforms.
Required Modules:
320 VCLFO or 390 uLFO or 300 VCO
700 VC Router
Oakley Multimix (MOTM mixer does not have enough gain, need gain of -1)
910 Cascaded Multiple
Connections
300/320/390 TRIANGLE to 700 CV IN
300/320/390 SQUARE/PULSE (set pulse at 50%) to MULT (Note: this needs to
be the same oscillator as the triangle wave)
MULT to Oakley Multimix IN1 and 700 IO A
Multimix OUT1 to 700 IO B
700 IO X is divided square out
Settings:
300/320/390 Rate/Frequency = any
700 Mode = voltage
700 Switch = 0 for square wave, any other setting for uneven pulses
Oakley Multimix IN 1 = -5
For modulation of pulse width, mix the TRIANGLE wave with a second LFO
sine or triangle, then feed that to the 700 CV IN.
Syncopated Clock with Random Probability
Another application for the lowly MOTM 700. This gives a nice
syncopated, semi-random clock, but always on the beat.
Required Modules:
100 or 101 Noise/S&H
700 VC Router
830 Dual Mode Mixer
Connections
320 PULSE or 390 SQR to Mult
Mult to 100/101 EXT CLK, 830 IN 3, 700 IO A
100/101 S&H OUT to 830 IN 2
830 OUT1 to 700 CV IN (A/B/X)
700 IO X is syncopated clock, send to ADSR gates
Settings:
100 LEVEL = 10, SLEW = 0
320 or 390 RATE = about 8
700 SWITCH = +0.5 to +3.5
830 IN 2, IN 3, BIAS (optional) = set to taste
Semi-random patch
Ingredients:
Any 2 LFOs
MOTM-820 VC Lag
Any LFO 1 waveform to 700 IO A
Any LFO 2 waveform to 700 IO B
700 IO X to 820 IN
820 OUT1 to 700 CV IN
820 OUT2 to any control voltage input, VCO pitch, VCF cutoff, etc.
LFO rate, Router switch, and Lag Up, Down and Up/Down will cause
significant change to the semi-random pattern. Adjusting the Lag
control too far to the right may cause the Router to stay pegged to one
side. The patch creates a feedback path so that lagged versions of LFO 1
and LFO 2 alternate control of the router switching.
John Loffink
The Microtonal Synthesis Web Site
http://www.microtonal-synthesis.com
The Wavemakers Synthesizer Web Site
http://www.wavemakers-synth.com
Re: [motm] Four MOTM-700 VC Router patches
2006-07-04 by Richard Brewster
Thanks very much, John!  I do remember you posting these before.  I have
added these to my website, credited to you, so we can all remember them
easily:
http://www.pugix.com/top-cabinet.htm#motm700
I did a bit of editing and added my Mixer-Comparator as an alternative
mixer in the patches.
Richard Brewster
John Loffink wrote:
> Full wave rectifier
> Ingredients:
> Signal source
> Pulse Divide by Two
> Required Modules:
> 700 VC Router
> Connections
> Settings:
> 700 Mode = voltage
> Required Modules:
> 700 VC Router
> 830 Dual Mode Mixer
> Connections
> Settings:
> Semi-random patch
> Ingredients:
> Any 2 LFOs
> MOTM-820 VC Lag
> 700 IO X to 820 IN
> John Loffink
2006-09-22 by Jason Proctor
another one, probably obvious to most 700 drivers ...
3-way switch
ingredients -
3 signal sources
MOTM-700
CV source, preferably bipolar (eg MOTM-320)
mult
connections -
CV source -> both MOTM-700 CV inputs
signal source 1 -> MOTM-700 IO A
signal source 2 -> MOTM-700 IO B
MOTM-700 IO X -> MOTM-700 IO C
signal source 3 -> MOTM-700 IO D
MOTM-700 IO Y is the output
settings -
MOTM-700 mode at audio or voltage depending on flavour of signal sources
MOTM-700 top switch bias knob at 10 o'clock
MOTM-700 bottom switch bias knob at 2 o'clock
the CV will then switch between the 3 input sources. the difference
between the two switch bias knobs is the size of the window where
signal 2 is selected. standard noise->S&H isn't a very good switcher
here because of its bell curve distro, some tweaking of the window
size is required.
let's have more 700 patches!
enjoy
j
2006-09-22 by Paul Bower
and the 700 makes a great little arpeggiator too with the help of Larry's wonderful voltage shift modules
(but now is a very bad time for me to do a patch - hopefully, over the weekend i'll get time...)
cheers
paul
3-way switch
ingredients -
3 signal sources
MOTM-700
mult
connections -
settings -
size is required.
enjoy
j
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
(Yahoo! ID required)
<*> To change settings via email:
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
Paul Bower
Label Manager
Awal UK Limited
www.awal.co.uk
yep that's exactly what i'm doing - i'm using the 700 to randomly
choose between the 3 notes which form the major chord of the scale,
set up with a JLH-822. this decision forms half of a melody voice, a
component of The Factory. The Factory is barely crawling right now
but when it's walking and puking i'll post more details....
>cheers
>paul
tip #1 - use the channel a to set up a 2 note arp, feed the output in channel b and...
tip #2 - use the channel b to set up a key change
of course it requires a pulse divider to drive all this - whether MOTM pulse divider (is that out yet ?) or wonderfully cheap CGS pulse divider (i love em) or a very simple divider built around a 4580 (i think)
cheers
paul
cheers
paul
Yahoo! Groups Links
Paul Bower
Label Manager
Awal UK Limited
www.awal.co.uk
2006-09-22 by xamboldt
Here's one I just threw together, I'm not sure if anyone has written
about it yet:
Waveshaper
Basics needed: VCO & 700. for modulation, a CV source (LFO, EG, etc)
and a CV mixer, and/or another VCO
Both switches are set to voltage
Take a sine or triangle from a VCO into Y of the 700
Plug C into A, and D into B
X will be the output
If you're using the sine from the VCO, plug the triangle into both CV
inputs (or vice versa)
Moving the knobs changes the waveform of the output signal.
If you first take the CV wave from the VCO, and mix it with another
CV source, and then plug it into the CV inputs, you can get some
modulation of the waveshaping, with different breakpoints being set
by the knobs.
If you plug another VCO into the top CV input, you can get some weird
FM stuff happening.
-Chris
> 3-way switch
> ingredients -
> 3 signal sources
> MOTM-700
> mult
> connections -
> settings -
> sources
> size is required.
> enjoy
> j
2006-09-22 by synth1@airmail.net
What a clever idea!
Paul S.
limited clever left
> about it yet:
> Waveshaper
> by the knobs.
> FM stuff happening.
> -Chris
>> 3-way switch
>> ingredients -
>> 3 signal sources
>> MOTM-700
>> mult
>> connections -
>> settings -
>> sources
>> size is required.
>> enjoy
>> j
2006-09-22 by Richard Brewster
The MOTM-120R with the DB-120 board makes a handy pulse divider:
http://www.tellun.com/motm/diy/db120/DB-120.html
It says that this is currently still shipping.  You would have to make
your own panel, now, as the original Stooge panel isn't available any more.
-Richard Brewster
> channel b and...
> cheers
> paul
2006-09-23 by Scott Juskiw
Yes, the DB-120 daughterboard is still available. I've been in
contact with Scott Deyo (mailto:contact@...) on the
synth panels group
(http://groups.yahoo.com/group/ModularSynthPanels/) regarding panels
for my sdiy projects, including the DB-120. If all goes according to
plan, you will be able to get Stooge-like panels for this in the near
future.
2006-09-23 by Scott K Warren
Now this is great news! I will buy some when they're ready. -- skw
On Sep 22, 2006, at 8:58 PM, Scott Juskiw wrote:
> I've been in
> synth panels group
> future.
