Ribbon Controllers
1999-12-03 by Tkacs, Ken
For those discussing ribbon controllers DIY, I found these excerpts on the web; hope this helps: "There is information on building a ribbon controller in "Electronic Music Circuits" by B. Klein. This one is basically a rheostat using a long strip of conductive foam such as you find protecting semiconductors from static charges. The foam is placed on non-conductive material (wood, etc.) and two metal plates are attached at each end. One plate is connected to ground and the other to a +15V supply. Now, at a slight distance above the foam you place a piece of metallized mylar film that leads to the Control Voltage out jack. When you press on the mylar film it makes contact with the foam somewhere between 0 and 15V. As you slide your finger along the film, the voltage changes." "I added a 2-foot long ribbon controller just above the keyboard, with a range of about +/- 5 octaves. I used black rubberized anti-static bag material for the resistive element, and a steel band about 1/4" wide for the ribbon. I mounted a separate linear power supply inside the case so as not to disturb the existing circuitry. The ribbon is buffered by a TL-082 which simply goes straight to all 16 VCO's via a 100K 1% resistor added to each VCO's summing node. There is no memory S/H cap, so the pitch is only affected when you press on the ribbon. Autotune still works, as long as you leave the ribbon alone during the tuning process. Now I can do CS-80 bends and get the VCO's down to a couple of hertz." "There are several [vendors for the resistive vinyl element], but one that I know from the top of my head is http://www.interlinkelec.com/ I don't know their current line up, but they are company we used back in the Oberheim days.--Tony Karavidas, Encore Electronics"
