MOTM
Making Mults
Making Mults
2006-07-18 by ithaib
Hi all,
I want to make a Mult Panel. Is the correct way of doing it connecting the Jack's Tip & Ground
to one another in a chain? Is this how the MOTM Mult is built?
Is it true that I lose a certain amount of dB with each connection? (like 3dB?) is there a way
around this?
I'll appreciate any insights on this.
Ithai B.
Re: [motm] Making Mults
2006-07-18 by Stephen Drake
Wire all the tips together, wire all the grounds together. You can
also do all sorts of fancy switching things using the switched jack if
you're so inclined, like the motm mult panel.
I use the bottom 8 jacks in my blacet-motm conversion panels, and make
2 sets of 4 multis. You can never have enough...
I've never noticed any signal loss. No more so than any other
connection in the system.
On 7/17/06, ithaib <ithaib@...> wrote:
> Hi all,
> Jack's Tip & Ground
>  around this?
>  Thanks,
>  Ithai B.
Stephen Drake
sduck409@...
makeme1witheverything@...
2006-07-18 by Richard Brewster
The multiple itself will not introduce signal loss.  However, if you
distribute a signal that uses the typical 1K series resistor on its
output and patch that to a lot of other inputs, there will be a small
signal attenuation, due to the voltage divider formed between that 1K
and the other input impedances.  Examples:
1K output to a single 100K input.  The signal is 100/101 or about 99% of
what's on the op amp output pin.
1K output to 4 100K inputs, which is equivalent to 25K.  The signal is
25/26 or 96%.  This is still a small attenuation, that you might not
notice unless you were driving 1V/oct VCO inputs, where the pitch
difference would be apparent.  Many controllers that drive 1V/oct for
pitch have something around 100 ohm output impedance in order to
minimize this problem when driving multiple VCOs.
In short, signal loss isn't much of a problem with using multiples.  If
you know the output and input impedances in your patch, you can do the math.
I never fully understood the choice of 1K as a standard output series
resistor.  Electronotes (Bernie Hutchins) used 1K.  I think one reason
is that you can hard patch 1K outputs together in a multiple and not
draw excessive current.  Most MOTM modules use 1K.  Serge uses 330 ohm
resistors here.  I've seen 100 ohms used on Blacet module outputs.
Richard Brewster
http://www.pugix.com
>> Hi all,
>> Jack's Tip & Ground
>>  around this?
>>  Thanks,
>>  Ithai B.
