MOTM
Cabinet and power requirments
2006-09-02 by Ben Stuyts
While waiting for the motm MOTM to arrive I'll be having loads of
time to think about a nice cabinet.
I see that the original MOTM rails are 19" wide. But I'll be building
my own cabinet anyway, and somehow a bit wider looks better to me.
For example, the 48" wide synthesizers.com cabinets look good to me.
Also, what is a good depth? The synthesizers.com is 8.5" I see.
What do you generally do? Are there any widths (except 19") and
depths that can be considered 'standard'?
Do you always use rails to mount the modules, or is wood okay too?
Is any cooling needed? I'll probably get a 40 or 60 W Power-One
linear supply. With an efficiency of about 50%, that is a lot of heat
to get rid of. I've read on these lists that they are used by other
people too, with good results. Are those also used in the original
MOTM power supplies?
With kind regards,
Ben
Re: [motm] Cabinet and power requirments
2006-09-02 by Richard Brewster
Thoughts below.
Richard Brewster
http://www.pugix.com
Ben Stuyts wrote:
> Hi,
I like mine a lot.  It is not too hard to convert one, if you can get
the right rails.  I don't remember who, if anyone, is supplying these now.
http://www.pugix.com/cabinet_new.htm
I need the 8.5 inch depth for Blacet and other conversions.  If you have
only MOTM modules, then half that depth should be sufficient.  The 8.5
inch depth also allows me to mount MOTM-depth modules in front of my
power supplies, which as you can see I mount in a non-standard way, off
the panel.
The cabinet width is largely up to you.  I have seen a lot of 24U width
cabinets out there.  Dot com conversion cabinets provide 26U, because
MOTM modules are narrower than dot com.  For me that comes to an extra
10U across all five cabinets.
I highly recommend rails.  You will be dismounting modules a lot and
wood holes deteriorate quickly.  Steel rails with good machine screws
last a long time, and if you cross thread a hole, it can be fixed.
Yes, MOTM supplies use Power One units.  Ventilation is important, but
you want convection, not noisy fans.  I removed the back from my
single-height dot com cabinets for serviceability, and this helps
ventilation.  The big slant cabinet has a closed back except for around
the power supply area, and a slit in front on each end of the top row,
where end caps are supposed to go.  I have wondered if that is enough
air flow.
> With kind regards,
> Ben
2006-09-02 by Paul Schreiber
I suggest a depth of a *least* 8in, because you need air flow and the largest
MOTM depth is about 5 inches. You need additional area for the power cables,
too.
Paul S.
RE: [motm] Cabinet and power requirments
2006-09-02 by Adam Schabtach
That's probably fine. Mine are a bit shallower than that, even.
I use wood. I haven't had any trouble with the threads wearing out, but I am
careful when I put screws back in, and I use high-quality square-drive wood
screws rather than cheap hardware-store screws. I personally don't see
enough advantages in metal rails to merit the expense, although it depends
on whether or not you like drilling lots of holes. :-)
I use pegboard for the backs of my cabinets, on the assumption that it
provides some convective cooling while keeping out most of the dust. I don't
know whether "pegboard" translates well into your language. :-) It's
wood-like material about 5mm thick, made from some sort of compressed
fibers, with holes about 5mm in diameter every couple of cm. People
traditionally use it to hang tools on by attaching sheets to walls and
inserting pegs (actually hooks) into the holes.
> Are those also used in the original MOTM power supplies?
Yes, SynthTech uses Power One supplies.
--Adam
If wood is a viable choice, then I suppose you could simply buy a dot
com walnut cabinet and start mounting modules.  You would need to drill
pilot holes, because the ones supplied don't match MOTM.
Adam, do you have a part number for the wood screws you use?  And can
you explain 'square-drive', please.
-Richard Brewster
They have square recesses in the heads, rather than a single slot or a pair
of crossed slots. The manufacturer, McFeely's, can explain them far better
than I can:
http://www.mcfeelys.com/tech/faq.asp
I use part # 0806-PSK-C for mounting modules.
--Adam
> From: Richard Brewster [mailto:pugix@...]
> Sent: Saturday, September 02, 2006 12:48 PM
> To: Adam Schabtach
> Cc: 'MOTM litserv'
> Subject: Re: [motm] Cabinet and power requirments
> buy a dot com walnut cabinet and start mounting modules.  You
> would need to drill pilot holes, because the ones supplied
> don't match MOTM.
> And can you explain 'square-drive', please.
> -Richard Brewster
> > but I am careful when I put screws back in, and I use high-quality
> > square-drive wood screws rather than cheap hardware-store screws. I
> > personally don't see enough advantages in metal rails to merit the
> > expense, although it depends on whether or not you like
> drilling lots
> > of holes. :-)
2006-09-02 by Scott Juskiw
Square head screws are very popular in my part of the world. One
thing I didn't see mentioned on McFeelys website is that you can
often jamb a screw onto the screwdriver so that it doesn't fall off.
This is incredibly useful when you are trying to insert a screw into
a hole at various angles; gravity becomes irrelevant. Try doing that
with a philips or a slotted screw head.
>than I can:
2006-09-03 by Ben Stuyts
Thank you all for your comments. Lots of useful information, also on
the linked websites. I have a lot of reading to do. :-)
I've ordered about 30 U width of kits, so maybe a slanted cabinet of
22U wide x 10 U high would be a good idea. (Similar to the QSC44 from
synth.com.) I'll probably go with some sort of rails, probably self-
made, as I can see things moving around a lot before they find their
final place.
Do you move modules around a lot? Or do they stay in their place
after a while? (For example, do you put all VCO's together, what do
you do when you add another one?)
Ben
2006-09-03 by John Laudicina
I am always shifting things around, everytime I get a
new module things get shifted  I have yet to come up
with the perfect set up.
 It seems I am always building another cabinet, last
weekend I built another side wing cabinet and I use
the stooges rails for all of the MOTM modules, for the
dot com modules I use no rails, just drill into the
wood, I wish the rails went both ways...  having the
rails make moving things around allot easier for me.
When I built my first cabinet I made my own rails and
to be honest it was a pain in the ass, it took several
hours with the drill press and taps.  I used aluminum
angle iron.  On that cabintet I still have those rails
on it but all of my newer ones are stooge rails.
worth every penny.
If you have any wood working skills you should build
your own cabinets, the money you save you can buy more
MOTM modules.
John
--- Ben Stuyts <ben@...> wrote:
> Hi,
> slanted cabinet of
> to the QSC44 from
> they find their
> final place.
> their place
> together, what do
> Thanks,
> Ben
Do You Yahoo!?
http://mail.yahoo.com
2006-09-03 by Richard Brewster
I like to keep similar modules together.  But as I add modules it
requires moving things around to keep adherence to this principle.  If I
add another VCO, then I make room for it next to the other VCO's.  That
probably means moving something that is not a VCO that was next to the
VCO's.  That leads to yet another shift.  Musical modules!  The last
time I played this game, two of them didn't get 'chairs'.  They await
the next cabinet.  But that does not mean they will necessarily go into
the new cabinet.  It means that space will open up somewhere.  Adding a
new cabinet results in a big placement upheaval.  The synthesizer that
does not get modules moved around is probably one that is not growing.
Richard Brewster
> Thanks,
> Ben
Ok, yeah, I can understand that.
Do you keep patch sheets? There's probably no use in keeping patch
sheets that mimic the physical layout then.
I just saw that the stooge rails are still available on the
stoogeindustries.com site. I thought that had come to an end after
the sad passing of Larry Hendry. But I'm still considering making my
own, just to use metric thread in stead of 8-32.
> MOTM modules.
Good point. :-)
Ben
Hi Richard,
> If I
> That
Wonderful! I hope to have similar problems one day. :-D
In the booklets accompanying Wendy Carlos' Switched on Bach box set,
there are a few patch sketches. It is hard to tell if they are just
schematic, or have any resemblance to the physical position of the
modules. Schematic is probably the way to go.
Ben
2006-09-04 by John Laudicina
My modular has many different brands of modules,
mostly MOTM, this is what I started with and is my all
time favorite format.  I had a problem trying to keep
all of the VCO's together due to the fact that I have
3 motm and 2 .com's (vco's) the problem is that the
.com dont fit into the MOTM holes so I found it was
easier to make a seperate cabinet for the .com oddball
size instead of putting filler spacers (which I did
for awhile, I made mults out of them).
The reason I like the modular setup is all of our
modulars are different due to the fact of mixing and
matching  equipment.  I dont think I will ever go the
route of the frac rack, those 1/8" jacks are too
tempramental for my big old hands, let alone my eyes.
I have been making my own panels out of aluminum and
painting them with a gray spray primer and then
painting them with a textured black spray paint that I
get at home depot, it looks pretty close to the MOTM,
not as durable.  My cabinets stay indoors and do not
leave the studio so they are pretty safe.  I would
rather spend my money on modules than on panels and
cabinetry.  My only mistake is I made the width of my
ccabinet only 18 units wide, I wish I made it 28 units
instead.  With the 2 wing cabinets it is now 30 units
wide.  The truth of the matter is I did not realize
that this is a addiction, I think drugs would have
been cheaper.
I enjoy building this monster more than trying to play
it, oh the insanity of it all.
John, I need to get off my ass and make more patch
cords and much longer....
> add modules it
> other VCO's.  That
> modules!  The last
> necessarily go into
> somewhere.  Adding a
> Richard Brewster
> in their place
> together, what do
> > Thanks,
> > Ben
Do You Yahoo!?
2006-09-04 by Adam Schabtach
> One thing I didn't see mentioned on McFeelys website is that
> you can often jamb a screw onto the screwdriver so that it
> doesn't fall off.
> screw into a hole at various angles; gravity becomes
> irrelevant. Try doing that with a philips or a slotted screw head.
Indeed. I've startled people who are unfamiliar with square-drive screws by
inserting a screwdriver into one of the screws in the vertical face of my
modular and letting go of it. It will hang supported only by the head of the
screw, nearly parallel to the floor.
McFeely's screws are to generic philips screws as Bourns sealed
potentiometers are to Radio Shack carbon pots.
--Adam
2006-09-04 by Scott Juskiw
Out of 6 cabinets, I have one cabinet that hasn't changed in two
years, the rest are always in a state of flux.
I keep patch sheets, but they do not resemble the physical layout.
Mine are hideously ugly, no graphics whatsoever, just a huge table to
write every pot/switch setting and which jack is plugged into which
other jack.
2006-09-06 by David Cornutt
> other jack.
Me too.  The thought has occurred to me that if I were sufficiently
clever, I could devise an XML schema for these settings and routings.
I could then write a program that would spit out graphical patch sheets
that would match whatever layout I'm using at the time.  But right now,
I'm not motivated enough to be that clever.
