MOTM
New MOTM-650 firmware released
2006-09-15 by Paul Schreiber
V1.2 is found at:
www.synthtech.com/m650
the SFI file requires the Updater.ZIP (Win XP) file.
This release fixes 1 bug, but it was a pain: when using MIDI Clock to drive the
arpeggiators, V1.1 would hang if you accessed certain menus. V1.2 corrects this
problem.
Paul S.
RE: [motm] New MOTM-650 firmware released
2006-09-15 by JAMES GALLANT
Paul,
      Will the 650's that have been ordered but not shipped yet contain
firmware V1.2?  I'm assuming that mine is among this group since my CC has
not been charged yet.
                  James
>From: "Paul Schreiber" <synth1@...>
>Reply-To: "Paul Schreiber" <synth1@...>
>To: "MOTM litserv" <motm@yahoogroups.com>
>Subject: [motm] New MOTM-650 firmware released
>Date: Fri, 15 Sep 2006 14:30:05 -0500
>V1.2 is found at:
>the
>this
>problem.
>Paul S.
Re: [motm] New MOTM-650 firmware released
Well, of course :)
Paul S.
To: <synth1@...>; <motm@yahoogroups.com>
Sent: Friday, September 15, 2006 4:44 PM
Subject: RE: [motm] New MOTM-650 firmware released
> Paul,
>                  James
>>V1.2 is found at:
>>the
>>this
>>problem.
>>Paul S.
2006-09-16 by Richard Brewster
Where can we find instructions for doing the update?
Richard Brewster
Paul Schreiber wrote:
> V1.2 is found at:
> problem.
> Paul S.
2006-09-16 by Paul Schreiber
There are no "formal" instructions yet. Basically, the steps are:
a) get the .SIT file and unpack Updater.zip from
b) when you run the program, it should automatically detect all MIDI ports on
your PC. There are drop-down selections if you have more than 1.
c) attach MIDI cable, turn on the '650
d) select the .SIT file
e) download
Paul S.
2006-09-16 by Neil Bradley
Slight corrections:
.sfi (not .SIT)
You need to select both an input and an output port.
Attach two MIDI cables - one in, one out.
.sfi file
> e) download
Click "Update".
-->Neil
C. Neil Bradley                KE7IXP		           Beaverton, Oregon
It is not working for me.  The program is able to connect.  The 650
display says 'Connected Await RX'.   I select the file and tell it to
update .  The update software says it is updating the firmware.  There
is a progress bar and then it says 'MIDI timeout'.  The 650 has to be
power-cycled to work again.  There is a Global Option called Patch RX
that is Disabled by default.  I tried enabling this, but it made no
difference.
Richard Brewster
> Slight corrections:
> .sfi (not .SIT)
> .sfi file
>> e) download
> Click "Update".
> -->Neil
> It is not working for me.  The program is able to connect.  The 650 display
> says 'Connected Await RX'.   I select the file and tell it to update .  The
> update software says it is updating the firmware.  There is a progress bar
> and then it says 'MIDI timeout'.  The 650 has to be power-cycled to work
> again.  There is a Global Option called Patch RX that is Disabled by default.
> I tried enabling this, but it made no difference.
Firmware transfer requires *NO* settings in the menu.
The OUT on one bus on your computer needs to be connected to the IN on the
MOTM-650. Sounds like it is since it's saying "Connected Await RX" (that
means it's in firmware transfer mode).
The IN of one of your MIDI buses on your computer needs to be connected to
the out on the MOTM-650.
If the IN and OUT ports in the SFUU aren't set correctly, you'll also get
this problem.
Double check your connections, and let me know.
-->Neil
2006-09-18 by Ben Stuyts
Hi Paul,
Just curious, as I have ordered a 650: Is there a way to update the
firmware from OS X? I don't have a pc with midi ports.
Ben
