MOTM
Re: [motm] Another WOO-WOO! -Building Tip
2006-09-23 by kheck73@aol.com
Just finished a 440 late last night. Sweet.
Thought I'd pass along a simple tip possibly already discussed.  I noted this
in a nice module built by Don  Ojeman. I obtained a heat gun with a low power
setting ($9 at the  local Harbor Freight), and 1/4" and 1/8" heat shrinkable
tubing. For the triple  twisted stranded going to outer pots, be sure the
strand is twisted tight,  then shrink 1/4" long collars of 1/4" diameter tubing
near the ends. Leave  enough individual wire length at the ends with longer
stripping (for the pot connections) to slip a 1/2" length of 1/8"  tubing over
each, and still have the bare wire end  exposed for soldering. If you need more
separate wire length  to push the 1/8" tubing farther away from the joint when
 soldering, I suppose you could put the unshrunk segment  of 1/4" tubing on
the cable just before finishing the pot connections, then  shrink it last.
I also put shorter 1/8" long collars of 1/4" tubing on the twisted pairs to
the switch and jacks, leaving the twists tight all the way up to  the
connections. Use a low heat setting, and wave the gun around starting  far away, then
moving closer while rotating the wires. The  gun gets really hot (even on low)
and can melt things or burn your fingers  if you get too aggressive.
The use of 1/8" tubing is mentioned in the module directions. Just before
soldering the pots, put a 3/8"-1/2" length of 1/8" diameter  tubing over the end
of each wire. If you didn't already collar  the pot end of the wire twist,
put a segment of 1/4" tubing on the bundle  before you solder the pots. When
soldering the connections, be careful not  to let your soldering iron get too
close parallel to the tubing, or let  heat rise from underneath, as the tubing
may start shrinking  prematurely (I hate it when that happens ;). Before
mounting the pots to the  panel, be sure you have good joints (you'll never see them
again), push the  tubing over the joint and up against the pots, then shrink
it. Don't get carried  away with the heat gun, it doesn't take much heat for
very long. Stop when  you see the contours of the joint appear from beneath the
tubing. Keep the  heat away from the PCB. I didn't put tubing over the switch
connections because  I wanted the twisted pair to remain tightly twisted all
the way up to the switch  (no room for tubing).
Just a little added extra touch worth an extra 15 minutes. You're  going to
build the thing only once.
-Karl.
RE: [motm] Another WOO-WOO! -Building Tip
2006-09-23 by John Loffink
Sounds like a ton of work to wire pots.  It always took more than 15 minutes
in my experience.
Why not just use these these:
http://www.wavemakers-synth.com/motm/chiclets.html.  :-)
John Loffink
The Microtonal Synthesis Web Site
http://www.microtonal-synthesis.com
The Wavemakers Synthesizer Web Site
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
kheck73@...
Sent: Saturday, September 23, 2006 12:34 PM
To: ppeery@optonline.net; motm@yahoogroups.com
Subject: Re: [motm] Another WOO-WOO! -Building Tip
tubing near the ends. Leave enough individual wire length at the ends with
longer stripping (for the pot connections) to slip a 1/2" length of 1/8"
tubing over each, and still have the bare wire end exposed for soldering. If
you need more separate wire length to push the 1/8" tubing farther away from
the joint when soldering, I suppose you could put the unshrunk segment of
1/4" tubing on the cable just before finishing the pot connections, then
shrink it last.
away, then moving closer while rotating the wires. The gun gets really hot
(even on low) and can melt things or burn your fingers if you get too
aggressive.
end of each wire. If you didn't already collar the pot end of the wire
twist, put a segment of 1/4" tubing on the bundle before you solder the
pots. When soldering the connections, be careful not to let your soldering
iron get too close parallel to the tubing, or let heat rise from underneath,
as the tubing may start shrinking prematurely (I hate it when that happens
;). Before mounting the pots to the panel, be sure you have good joints
(you'll never see them again), push the tubing over the joint and up against
the pots, then shrink it. Don't get carried away with the heat gun, it
doesn't take much heat for very long. Stop when you see the contours of the
joint appear from beneath the tubing. Keep the heat away from the PCB. I
didn't put tubing over the switch connections because I wanted the twisted
pair to remain tightly twisted all the way up to the switch (no room for
tubing).
-Karl.
In a message dated 9/23/2006 2:30:35 P.M. Eastern Daylight Time,
jloffink@... writes:
in my  experience.
You're right about the time factor. I meant it takes 15 minutes  just to add
the shrink tubing. I think it took me about hour  to completely wire up just
three pots and a switch. The chiclets look  like real time savers.
I used an extremely poor excuse of a digital camera to post a picture to  the
group of what I did ('MOTM 440 Wiring'). Looks better in real  life ;).
-Karl.
