MOTM
solder question
solder question
2006-09-26 by Jason Proctor
hey paul, have you changed the type of organic solder shipped with
kits? i put together two identical boards tonight - one is done with
organic i had lying around from a kit i bought a while back, the
other is done with organic that arrived with my 700 kit today. with
the new stuff, there's considerably more flux left on the board after
a wash.
Re: [motm] solder question
2006-09-26 by Paul Schreiber
> a wash.
This has come up 2 or 3 times over the last 2 years. I have *no explanation*,
the solder is the same for the last 10 years. It could be many things, such as:
a) soldering iron temperature. Needs to be between 695F and 705F. If you solder
over 705F, the flux 'boils off' too quick. If you solder too low, then the flux
does not spread evenly
b) minerals in the water. The best thing to use is distilled water.
c) surface contaminates on the pc board
d) replace the tip on your iron
Paul S.
well i'm glad that you didn't say "oh shit, we have a roll of
no-clean masquerading as organic" !
are there any other factors? in this particular case, the *only*
difference is the solder. the two boards are the same design shipped
at the same time from the mfr in the same little baggie. they have
been stored and handled identically.
they were soldered within an hour of each other with the same iron,
which had been up to temperature for an hour or so. the tip was
bought new with the iron last year and has about 10 modules on it.
soldering was done before & after board washes. all washes done with
the same water, and rinsed with the same filtered water.
oh and the last few parts on the first board i did were done with the
"new" organic. same result - much more flux. i've never seen flux
remain like this before.
how often should one replace a tip? how can i tell if it's on the way
out? this one seems as good as ever to work with.
2006-09-26 by Jay
I've never had the organic flux not wash off. I just bought a new roll
and it works as good as the old stuff. I would assume in this case
someone has labeled the package wrong...
RE: [motm] solder question
2006-09-26 by Adam Schabtach
> I would
> assume in this case someone has labeled the package wrong...
I suggest comparing the relative sizes of the two kinds of solder. In MOTM
kits, the no-clean stuff is a heavier gauge than the organic.
--Adam
well, i sent the ball back to the heavily-staffed solder analysis
dept at motm megacorp, inc, so we'll see.
