MOTM FS Update
2006-10-30 by Joe Bruno
Had one person back out of the last sale. Also found some kits that haven\u2019t been put together that I need to sell.
1 MOTM-410 Triple Resonant filter that has been modified with a switch on the front panel to switch from use with other modules to use with external instruments. There\u2019s an option on the board for this but it only uses a resistor but I used a switch so I could use it with modules and external gear. $225
1 MOTM-101 Noise/S+H $150
1 MOTM-110 RingMod/VCA $175
1 MOTM-700 Dual VC Router $140
1 Time Machine in Blacet Format with ΒΌ inch Switchcraft for the audio in/out $275
1 MiniWave Blacet format $180
1 Dark Star Chaos which I don\u2019t know how much they are anymore so a reasonable offer
All assembled by me and working perfectly. USA only. Priority goes to people who want multiple items.
The rest are kits with instructions and everything you usually get from Paul.
1 MOTM 110 $100
1 MOTM-380 Quad LFO $125
1 MOTM 390 Dual LFO $110
1 MOTM 490 Moog LPVCF $160
1 MOTM 820 VCLagProcessor $190
1 MOTM 890 MicroMixer $110
All are KITS. USA only. Again priority goes to person who wants multiple items.
Thanks
Joe Bruno
1780 Executive Drive
PO Box 84
Oconomowoc WI 53066
CONFIDENTIALITY NOTICE: This message is intended only for the use of the individual or entity to which it is addressed, and may contain information that is privileged, confidential and exempt from disclosure under applicable law. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
