MOTM
Realistic cabinet/panel dimensions
2006-11-08 by knight_of_pan
I've been gathering the materials to build a MOTM cabinet to have ready when my first
module kits arrive from Paul.
However, I feel like it's a bit of a gamble for me to go by the theoretical dimensions of the
panels vs. actually having one in my hands, since I don't have any actual panels to
measure from. So, I have a few questions perhaps someone who's built their own cabinet
can answer or confirm:
1) Will traditional rack rails work for the horizonal mounting structure (meaning: will the
hole spaces on the MOTM panels line up with the hole spacing of traditional rails)? I've
seen some right-angle mountable rails for sale on eBay that look like they'd work well for
using inside a wooden cabinet.
2) The MOTM catalog states that a 1 unit panel is 1.735" x 8.720". May I assume that the
actual physical space for a panel, taking into consideration that a little gap is necessary,
round up to 1.75" x 8.75"? In my case, I've planned for a cabinet that is 17U wide, and 2U
tall. By my calculations, I'm guessing it would be 17 * 1.75 = 29.75" wide, and 2 * 8.75 =
17.5" tall. Are these calculations realistic?
3) Will 8 inches of module depth going to be enough (please hold the jokes...!) for most of
the modules out there (MOTM, Oakley, as well as conversions... Blacet, Cyndustries, ect)?
Thanks in advance,
Cecil
[motm] Re: Realistic cabinet/panel dimensions
2006-11-08 by > angelzero <
Hey man!
I built my cabinet 9" deep and its been more than
sufficient.
My deepest module is the blacet time machine.
From the back of the front panel to the edge of the
stooge bracket measures about 7 3/16" (just measured).
You should be ok with 8" if you dont mount your power
distribution boards on the back, but rather on the
bottom interior of the cabinet (for each row).
However, if you choose to mount your power supply in
the back, you will have more options for module
placement if you build a deeper cabinet.
My cabinet was built to the 1.75" x 8.75" panel specs,
but I added 1/32" slop (to the 8.75" vertical
measurement) just in case, and it was a good idea.
Strangely, my -800 eg is a tight squeeze in some spots
in the cabinet (which must not be perfectly straight).
 On the other hand, my dual vca has about 1/16" gap
(short) lengthwise.  There must have been some
variation over time with the motm panel manufacturing.
My cabinet is a 24U and was built exactly 42" wide
(interior).  Despite this, I still have about 1/16"
gap on both sides of the cabinet, which is too small
for me to notice (it is not a visual distraction).
If you build a little large and use 1/2" lip for
mounting the modules you should be safe, as the panel
mounting holes are much larger than the screws and
will allow you to shift the modules around a bit.
Hans
> Thanks in advance,
> Cecil
__________________________________________________________________________________________
Sponsored Link
Talk more and pay less. Vonage can save you up to $300 a year on your phone bill.
Sign up now. http://www.vonage.com/startsavingnow/
