MOTM
Organic solder that won't wash off
2006-12-17 by Paul Schreiber
A few months ago, Kester shipped us 3 spools of the 'organic' flux solder (that
you wash off with water) that in reality was no-clean solder.
I was hoping that Indiana had flushed out all of the mismarked solder.
However, someone that just received a kit shipment had some of this solder.
So, here is what I suggest:
a) when you start a kit, solder just a *few* parts with the bag marked organic
solder, then wash
b) if the flux does NOT wash off, throw the bag of solder away
c) email me and I will send you more if you need more. Chances are you have lots
of extra organic solder (unless you are a newbie)
Now, if you solder the pcb with the no-clean solder, the board IS PERFECTLY OK.
The reason the flux doesn't wash off is that it is not *supposed to*, it's a
humidity barrier that prevents oxidation. This flux is NOT like rosin flux (the
brown gook) which is in fact a moisture *attractor*.
Paul S.
Re: [motm] Organic solder that won't wash off
2006-12-17 by Jay
But it looks so damn nasty with 1000 little balls of hardened flux all
over the board.
2006-12-17 by John Mahoney
>PERFECTLY OK.
Dumb question: Why not just use the no-clean if that's what we got?
john
>>PERFECTLY OK.
You can, but it doesn't look near as nice :)
Paul S.
