MOTM
440 ring modulates?
440 ring modulates?
2007-03-26 by sduck409
I've had my 440 for a while, built it from a kit maybe a year ago, but haven't had a lot of time
to mess with it besides some basic usage. Last night I was using the mixing part of it for the
first time, and noticed an anomoly - the inputs are ring modulating each other. Two
oscillators (300s), into inputs 1 and 2 (or any other combo), and twiddle the frequency knobs
on the oscillators, and I get all kinds of extra sideband frequencies. Sounds just like a ring
modulator. The exact same patch into my 480, and no problems, just the 2 frequencies, not
interacting. Guess I've done something wrong - any ideas what?
Steve Drake
Re: [motm] 440 ring modulates?
2007-03-26 by David Moylan
Also, some sort of clipping could add intermodulation sidebands, but the
output would likely sound noticebly distorted.  Are the sidebands clean,
maybe try two sinewave inputs with low resonance and high cutoff.
Dave
Mark wrote:
> I don't think there is a way to break a 440 in order to turn it into
> a ring modulator.
> Is it possible that what you are hearing is phase cancelation?? Can
> you get the same effect with the bass enhance set to normal, and the
> resonance set at zero??
> You would also get unexpected results if you accidently swapped one
> or more of the inputs on the front panel. For example, and I have
> not tried this myself, if you sent audio to to the resonance input
> you might get a ring mod effect (a VCA is two-quadrant multiplier, a
> ring-mod is a four-quadrant multiplier, and sometimes a VCA, even
> something like a limiter, can malfunction as such).
> I would check to see if all of your jacks are labeled properly.
> On 3/26/07, sduck409 put forth:
>>each other. Two
2007-03-26 by Mark
a ring modulator.
>each other. Two
