MOTM
Power supply upgrades.
2007-04-11 by earthtodylan2000
Thanks everyone for the helpful replies.  This is another reason that I'm so glad I started a
MOTM based system.
I was thinking of using a larger Power One supply so what one?
Ultimately I would like to use something like the .com power connection between cabinets
but much more solid as Mark said with better connectors.  So the consensus is?
When you mention digital modules other than the 650 what would those be?  ZO? Binary
Zone? Mini-Wave?
Again thanks,
Dave
Re: [motm] Power supply upgrades.
2007-04-11 by Henry Till
Sir Scott Stone,
Comments inline.
Check out the Power-One CP131A.  It's got 5VDC @ 8A and +/-15VDC @
3A.  Should be beefy enough for an expanding system.  You might use
the CGS PSU Delay Boards if you go with one this size, to prevent
latch-up.  Another option is getting something like the Power-One
HCC15-3-A for your +/-15VDC and a separate 5VDC supply.
> consensus is?
You could use the Neutrik 4-pin Speakons, wiring +15V, -15V, ground,
and +5V on the 4 pins, but it's probably good to keep your analog and
digital grounds separate for noise's sake, so the 8-pin Speakon might
be better.  Those guys can handle 30A continuous per contact, so they
are definitely strong enough, whereas the DIN connectors are better
for smaller distribution schemes.  With speakons, you can just use a
Speakon cable between different cabinets.
You might get some distribution ideas here:
http://www.wiseguysynth.com/larry/cabinet/cabinet2.htm
http://www.wiseguysynth.com/larry/power.htm
http://www.pugix.com/overview.htm
On an unrelated note, I really dug your performance with Melvins @
Symphony Space last year.  Lysol w/Haino was intense, though Haino
was almost too much - wish he knew those changes!
-Henry
