MOTM
heat sink compound
heat sink compound
2007-08-19 by jneilyahoo@jneil.com
The heat sink compound required for the 420 filter kit, does it matter
if that's silicon or non-silicon?
http://www.hmcelectronics.com/cgi-bin/scripts/product/3480-0008/
http://www.hmcelectronics.com/cgi-bin/scripts/product/8591-0060/
Also, are there any other kits that require it?  If not, then I might
just try to buy it in the little 1-gram packets instead:
http://www.mouser.com/search/refine.aspx?Ntt=heat+sink+compound
----------------------- Tear Along Dotted Line -----------------------
John Neilson                                           jneil@...
    this message brought to you by 'e-mail' -- safe, clean, Modern!
Re: [motm] heat sink compound
2007-08-20 by Stephen Drake
I use the silicone based kind you can get a Radio Shack for quite a bit less than any of those prices. I don t think it matters if it s silicone or not. And
2007-08-20 by Paul Schreiber
a) either one will work fine
b) all kits that use a TEMPCO resistor need some.
Paul S.
