MOTM
Oscillator Driver
Oscillator Driver
1999-12-20 by Tkacs, Ken
Anybody have any thoughts on this? It may be premature, since I only have
one MOTM VCO built at the moment with two more on the way, but...
With multiple VCOs, I assume I'll take the keyboard CV, feed it into a jack
multiple, and plug the other, say three, cables into three VCOs.
At what point would such a setup need to be buffered? If I was driving, say,
ten VCOs, is an "oscillator driver/buffer" of some sort needed? Does the
average keyboard or MIDI/CV device put out enough current to drive a whole
bank of these babies without problems?
Am I demented for having such a worry?
Re: Oscillator Driver
1999-12-20 by Paul Schreiber
Fair question.
I'd say probably most output stages can drive about 10-12 inputs, easy. 20,
probably.
There will be a point where the voltage each module "sees" will drop enough
to be audible, due to the parallel resistance of all the input summing
resistors.
But then a retune will fix you right up.
You are just heating up the 100Ks in the inputs more.
Paul S.
To: 'MOTM Forum All' <MOTM@onelist.com>
Sent: Monday, December 20, 1999 9:06 AM
Subject: [motm] Oscillator Driver
> From: "Tkacs, Ken" <Ken.Tkacs@...>
jack
say,
