MOTM
Kit solder mixup?
Kit solder mixup?
2007-11-18 by David Moylan
Do I recall some non organic solder being sent out in kits labeled as
organic?  I used some I still had in a bag marked 'organic solder'.
It's definitely the thin stuff compared to the no-clean solder. Just
used it to solder my bi-n-tic.  I went to do a board wash, but the flux
isn't rinsing off even with the gentle scrub of a soft bristle tooth brush.
Anyone know if RatShack stocks flux remover.  I had a can, but can't
seem to find it.
Thanks.
Dave
Re: [motm] Kit solder mixup?
2007-11-18 by David Cornutt
> organic?
I don't recall that.  I did have one kit a while back where the included
organic solder was a little strange (it didn't want to wet the metal,
and
I had to use a higher temp than normal), and I recall some other people
having similar comments at that time.  This might have been about
three years ago.  I can always tell the organic solder apart from the
no-clean by smell.  The organic stuff has kind of a sweet smell when
you heat it.  The no-clean doesn't have much of a smell.
> seem to find it.
Pretty sure they don't carry it anymore.  Mouser has it.
2007-11-18 by mcb, inc.
> organic?
There was a mixup about a year or so ago.  Think it was no-clean
for organic but I'm not absolutely certain about that.
Monty Brandenberg
2007-11-18 by Paul Schreiber
About 1 year ago, Kester mis-labeled 1 roll of organic that was really
no-clean. This went out to ~45 kits. The solder is *still OK*, it just looks
crappy.
Paul S.
Looks don't bother me but does the flux residue pose any potential
leakage paths or can I just leave it?  This is a VCO after all. Is it
worth cleaning with flux remover?
Thanks.
Dave
> looks
> crappy.
> Paul S.
