MOTM
Logic LE to MOTM-650 HELP!
2007-12-05 by earthtodylan2000
Hello,
Can anyone walk me through this?
I can record MIDI track into Logic but I cant get them to the 650 to then go to my MOTM
system I have no problem when I use other synths like my Voyager...
I have a Mac Mini running Logic 7.2 with a Presonus Firebox as a Audio/Midi interface.
I'm sure it's just some sort of configuration problem but I can't figure it out...
David Scott Stone
Re: [motm] Logic LE to MOTM-650 HELP!
2007-12-06 by Mark
Well, the first thing to do would be to check the 650.  Have you
tried plugging a keyboard (or something else that generates MIDI
notes) directly into it without using your computer and MIDI
interface??
If that works, then I would try connecting the 650 to the Firebox
with the same cable, then go into Audio MIDI Setup in OS X, set up
the 650, and test it from there.
If that works, then I would go into Logic and see if the 650 shows
up.  Then make sure that the 650 and your MIDI data are set to the
same MIDI channel.
On 12/5/07, earthtodylan2000 put forth:
>Hello,
>then go to my MOTM
>figure it out...
>Thanks,
>David Scott Stone
