MOTM
Making power cables
Making power cables
2008-06-09 by Jeff Laity
What is the secret to making a MOTM power cable with the MTA-156
connectors? Do I need a crimper to attach the wires? I try to get them
in there with a set of pilers but that doesn't work. Last time my
cable didn't work so I just blobbed molten solder on there to close it
up. There must be a better way. Are you supposed to strip the wire
first? I'm using 18 gauge wire.
Thanks, -jl
Re: [motm] Making power cables
2008-06-09 by Scott Juskiw
You can get some tools for
fixing wires into MTA connectors (Mouser part numbers):
         571-598041
          156 T HANDL MAINT TL
          AMP MTA .156' Connectors
         571-598031
          100 T HANDL MAINT TL
          AMP MTA .100' Connectors
These aren't the fancy ones with a trigger; these are the T-shaped
ones that still require a vice to hold the connector and a bit of
grunting to get the wire in place. I've found these tools to be much
more reliable than the old pliers method, especially when building 20
power cables. The results are consistent and perfect each time.
> Thanks, -jl
2008-06-09 by Scott Deyo
There are two styles -- crimped pin, and press-in.
I use the crimping tool and pins for mine.
When I goof and order those press-in bastards (excuse me!), I strip a
bit of the wire and solder it in to make extra-super-sure.
But then I always have that feeling that I'm punk-rocking that which
should not be punk-rocked.
Probably it's that nagging voice in my head, saying, "It's only a
matter of time until that sharp little jeweler's flat-head slips and
plunges into your wrist, ya daftee."
Paul, do you have one of the fancy tools? What do you use?
Scott Deyo
The Bridechamber
contact@...
http://www.bridechamber.com
Jealous Edison Record Kompany
http://www.jealousedison.com
>  571-598041
>  571-598031
> them
> it
>  > Thanks, -jl
Re: Making power cables
2008-06-09 by djbrow54
I ground a screwdriver so I can press them in.  I don't trust them,
so I put the connector sideways (to avoid gravity) in a vice and
solder the wires.  You need to solder quickly.  I usually tin the
wires first.  Works great.
Dave
them
it
> Thanks, -jl
RE: [motm] Making power cables
2008-06-09 by JAMES GALLANT
I just buy these things:
http://www.allelectronics.com/make-a-store/item/CON-234/4-PIN-CONNECTOR-W/HEADER-.156/-/1.html
James
>From: Jeff Laity <synthetic@...>
>To: MOTM List <motm@yahoogroups.com>
>Subject: [motm] Making power cables
>Date: Sun, 8 Jun 2008 18:46:18 -0700
>Thanks, -jl
2008-06-09 by krisp
I've got one of the fancy amp trigger type guns with heads for the 156 and the 100 connectors
it was not cheep but after I sent a screw driver through my hand I ordered one
It makes it so quick, easy and risk free
Sent: Monday, June 09, 2008 2:46 AM
Thanks, -jl
2008-06-09 by Mark
On 6/8/08, Jeff Laity put forth:
Using the right gauge wire is important.  What I do is take
unstripped wire, then using a needle-nose pliers with the jaws open
just a little bit, with one jaw on each side of the V-shaped tab,
then press the wire down.  Which has worked fine so far.
Although, I have a relatively small modular with mostly Synthesis
Technology modules that came with assembled cables.
If I remember correctly, I also received some power connectors with
the Blacet kits for the Time Machine and Mini Wave that used crimp
pins.  For those, I just used a pair of stakons:
http://www.drillspot.com/products/73941/Sta-Kon_WT112M_Crimping_Plier
2008-06-09 by John Blacet
The Blacet web site has two power cable kits that provide everything you
need for 4 pin cables although you will have to supply 6 pin connectors
for the larger MOTM cables.
John Blacet
John Blacet
Making power cables
2008-06-09 by Paul Schreiber
(resending, having some email issues)
 a) first you need the correct wire:
 http://stevenengineering.com/tech_support/PDFs/37PCBMTACN.pdf
 which for 18ga. is UL 1007.
b) MTA = Mass Termination Assembly = IDC = Insulation Displacement
Connector.
That means: a special tool is needed to "cram" the *stranded*  wire into the
connector so that little blades slice through the insulation
 and make contact with the wire. Same thing that ribbon cables do, but on a
 larger scale
 c) There is a low-cost AMP tool, Mouser (www.mouser.com) part #571-598041
 (for MTA-156) and also #571-598031 (for MTA-100). This is used to 'cram'
 the wire into the contact, assuming that the connector is somehow secured
 beforehand (I've use a PanaVise). These are $22.00ea. I use a pneumatic
 machine with a "feedthrough" tool that cost $430. But I've made over 8,000
 cables so big deal
 d) note that MTA-156 is designed for 18ga wire with PVC insulation rate
 300V or less (this is to control the thickness of the wire versus the
 thickness of the insulation).
e) also note there are "dust covers" that slide over the female IDC
 connectors. The Mouser part number for the 4-pin MTA-156 is a #571-6405514
 and these run $0.18ea.
> Paul S.
Re: [motm] Re: Making power cables
2008-06-09 by Richard Brewster
I'm with Dave on this.  The solder-less approach, while "correct",  is
better suited to a mass production assembly line that warrants purchase
of the expensive tools and exactly correct wire (see Paul Schreiber's
post on this).  Making these by assembly line will go much faster this
way.  But for DIY the connections are easily soldered, being careful not
to melt the plastic connector too much.  It takes a little skill, but
heck, this is DIY.  Soldering works for any size of wire, although
choice of a gauge (#18 or #20) that fits the pin is best.  #18 wire is
overkill unless you're making a long cable.  Use stranded wire for
flexibility.
My technique is to hold the header in a tiny vise, tin the wire, and
push it carefully into the pin with a small screwdriver.  Then make a
good solder joint that properly heats both the wire and the pin with the
solder applied to the work (not just to the soldering iron).  I've never
had any problems.
Richard Brewster
http://www.pugix.com
> Dave
> them
> it
>> Thanks, -jl
2008-06-10 by Jeff Laity
The AMP tool would have taken, like, days to get here, so I came up
with my own system that worked pretty well:
1. Put 18 ga. wire in slot and push it down a bit
2. Put a small allen wrench on top of the wire
3. Use pliers to squish allen wrench down on top of wire (I used some
pliers that press down in a parallel line)
4. Use pliers to squeeze either side of connector together.
I got six out of six working power cables, so I'm happy. Next time
I'll probably try stripping and tInning the wires, or buying the right
tool for the job. (Psssh!)
