MOTM
JH. Hammond Scanner Vibrato emulation: taking orders now
2008-06-25 by JH.
I have sucessfully built and tested a prototype of my new PCB project, and
I'm
starting to take pre-orders for these PCBs now.
To avoid any confusion: There is *one* PCB that allows to build two
different projects:
(1) 9-Stage Interpolating Scanner Module with onboard VC LFO
(2) Emulation of Hammond Scanner Chorus / Vibrato
I've sent out two separate mails for the two applications, but it's based on
the *same* PCB.
So if you want to build three Interpolating Scanner modules plus two Chorus
/ Vibrato devices, simply order 5 "Scanner PCBs", using the order form
below.
A description of the projects can be found here:
http://www.jhaible.heim.at/interpolating_scanner_and_scanvib/jh_interpolating_scanner_and_scanvib.html
In addition to the sound effect, this could be a quite nice optical effect
in your front panel, too:
http://electro-music.com/forum/phpbb-files/jh_scanvib_2008_quick_and_dirty_466.mov
(Better sound samples are on my web site, see above.)
Like the previous Tau project, the PCB allows the connection of a mains
transformer + fuses if you are skilled in working on mains voltage, or the
connection of an AC wallwart of about 16 ... 18V (AC), or you can power it
from a clean +/-15V Dual DC power supply.
For the latter, you'll have to solder in wires, however. There was no room
for a MOTM or synthesizers.com power connector.
Scanner order form
Email subjet line: "Scanner PCB order [n] sets of boards"
Email text:
I'm ordering [n] Scanner PCBs
for EUR 27.00 per board
plus EUR 4.00 for shipping and handling per order.
There may be addional tax and / or customs fees in my country - these will
be paid by me (the buyer), not by the seller.
I'm aware that I'm only buying a blank PCB that may help me building a
Scanner module - I'm *not* buying a diy kit, not a "project" -  just a pice
of FR4 with
copper traces. By placing my order, I agree to these terms.
My adress is:
[Full shipping adress, as it will appear on the envelope for sending you the
PCBs]
My paypal adress is:
[your paypal adress]
(Don't forget the email subject line with the number of PCBs ! )
Looking forward to hear from you,
JH.
