'730 VC Divider demos are up!
2008-07-13 by Paul Schreiber
Go to: www.synthtech.com/new_stuff.html scroll down to the MOTM-730 section, the demos are listed along with some production information. The demos show the divider being used "normally' (to use a master clock to trigger multiple EGs, which then gate the voices through the VCAs) and as a "tone generator" a la Hammond organ (input a high frequency, generate multiples below and mix together externally). The last demo is the introduction to Robert Rich's 'Electric Ladder' CD. The divider sequence begins at the 2:00 mark and continues to the end of the snippet. This portion is overdudded 3 times and if you listen carefully you can hear the 3 sets of voices being triggered at the 3 different clock rates. And just for grins, this piece is in JI tuning via the MOTM-650 MIDI-CV. This recording was done with the breadboard :) Comments welcome. Paul S.
